looney2ns
It's obvious you have not bothered to read the link I mentioned.
You need to learn what you don't know.
Wifi absolutely sucks for security cameras. You run the risk of bringing down your entire Wifi network.
Wifi was never designed to have continuous data streaming of the likes that security cameras will create. It will choke.
Bandwidth-you will use tons of upload bandwidth if you go the cloud route. Don't do it.
There is many, many folks here with tons of experience.
If you want a system that is reliable, secure, and robust, then you need to study to learn what you don't know.
It's obvious you didn't bother to read the link I supplied to you above. Carefully study it.
"Any job worth doing, is worth doing correctly."
All of it.Which path ? Wifi cameras?
