Rack mounting Hikvision 9632
cutterman
Jan 25, 2017
104
17
Hi
Finally organizing my network closet and getting a rack. I have the 9632 Hikvision NVR loaded with 8 HD's so it is heavy.I have the rack mounts that came with the unit.
Anybody have any experience rack mounting one of these? Seems like a lot of weight to support from the front rack mount.
Thanks
Why not get a rack shelf and just place it on that.
Reactions: Mike A.
Probably OK. I've rack-mounted some big heavy servers. But I've not seen what Hikvision does for it's mounts. You could get a rack-mounted shelf if you're concerned about it and likely use both to take up the space side-to-side.
Thanks for the replies. I did order an extra rack shelf just in case.
Follow up: so it rack mounted fine. The weight of the hard drives is mostly up front. I used a ratcheting strap to hold it in position to secure the cage screws. Before and after below. Cameras on top POE switch and data network on switch below, along with a PC running a linux firewall, mac mini file server, and a couple of Sonos amps.
Maybe I'll get around to tidying up the cables but probably not;) Just happy everything works.
Reactions: Mike A.
