R6 DS-2CD2542FWD-IS BootLoop
DrGEM
Apr 9, 2020
11
Moldova
Hi. I hawe 2 camera R6 DS-2CD2542FWD-IS with similar defect - bootloop. What happened to them before is unknown. Log is identical.
U-Boot 3.1.6-195297 (May 25 2016-11:39:03)
boards:195277
Boot From: NAND 2048 RC
SYS_CONFIG: 0x30060059 POC: 100
Cortex freq: 600000000
ENET freq: 50000000
iDSP freq: 216000000
Dram freq: 564000000
Core freq: 216000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
dev_model:DS-2CD2542FWD-IS
*** Warning - bad CRC, using default environment
crc=0xC1CD2D34,env.crc=0xFFFFFFFF
|NUL eth|
cmd 'null' is not supported.
nand booting ...
booting from pri part...
load kernel...
init started: BusyBox v1.19.3 (2019-08-26 15:55:19 CST)
starting pid 46, tty '': '/etc/init.d/rcS'
Starting udev: [ OK ]
UBI device number 1, total 272 LEBs (34537472 bytes, 32.9 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi1_0.
pri_iUpgSuccCnt:1, sec_iUpgSuccCnt:1
UBI device number 3, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi3_0.
Check dir /davinci ok! (0)
UBI device number 4, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi4_0.
Check dir /config ok! (0)
diagnose_way = 15, repair_way = 1, interval = 60
route: ioctl 0x890c failed: No such process
Default method to init without VIN drivers...
Cat this file to find out what VIN can be supported.
Default init without lens driver
Use default settings
/home/script/init.sh: line 553: which: not found
[ 19.925251] [ kernel version: svn-594950 ]
map_size = 0x400000, nr_item = 3
addr_offset = 0x00000000, filename = orccode.bin
addr_offset = 0x00300000, filename = orcme.bin
addr_offset = 0x003a0000, filename = default_binary.bin
mmap returns 0x76ab0000
loading /home/firmware/orccode.bin...addr = 0x76ab0000, size = 0x171cca
loading /home/firmware/orcme.bin...addr = 0x76db0000, size = 0x51644
loading /home/firmware/default_binary.bin...addr = 0x76e50000, size = 0x40000
ucode (S2L) version = 2017/5/25 271820.271498
ln: prtLensCurve: File exists
ln: /dev/ttyS1: File exists
ln: /bin/t1: File exists
cp: can't stat '/dav/libutils.so': No such file or directory
chmod: /lib/libutils.so: No such file or directory
ln: /dev/rtc: File exists
=====check_config start=====
===db file doesn't exist===
==== both config files are broken====
infd read End
Unix bus 0 .
Enter DB_main-------------------
shared memory address is: 0x76bbf000, sizeof(DEVICECONFIG) = 1159944
netprocess Infomation:
version: 8.11.3 [14:45:39-Jun 22 2018]
Path: /Camera/Platform/Trunk/FSP_network_protocol
Last Changed Rev: 404021
Last Changed Date: 2018-06-22 14:14:20 +0800 (Fri, 22 Jun 2018)
wait davinci set default...
[04-09 13:15:03][pid:572][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[04-09 13:15:03][pid:579][STRM_ANLS] [ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[04-09 13:15:03][pid:579][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[04-09 13:15:03][pid:579][UNI_IF][ERROR]communicaite_to_davinci failed!!!
copy default.cls ok.
[04-09 13:15:04][pid:572][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[04-09 13:15:04][pid:579][STRM_ANLS] [ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[04-09 13:15:04][pid:579][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[04-09 13:15:04][pid:579][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[04-09 13:15:05][pid:572][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[04-09 13:15:05][pid:579][STRM_ANLS] [ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[04-09 13:15:05][pid:579][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[04-09 13:15:05][pid:579][UNI_IF][ERROR]communicaite_to_davinci failed!!!
Unix bus End
shared memory address is: 0x769bb000, sizeof(DEV_CAPABILITY) = 464336
[04-09 13:15:05][pid:593][HW_IF][ERROR]sec info get inval!!!
[04-09 13:15:05][pid:593][SYSINIT][ERROR]hwif_getsecinfo failed.
[04-09 13:15:05][pid:593][SYSINIT][ERROR]sys app init failed to reboot!
[04-09 13:15:06][pid:572][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[04-09 13:15:06][pid:579][STRM_ANLS] [ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[04-09 13:15:06][pid:579][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[04-09 13:15:06][pid:579][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[04-09 13:15:07][pid:572][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[04-09 13:15:07][pid:579][STRM_ANLS] [ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[04-09 13:15:07][pid:579][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[04-09 13:15:07][pid:579][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[ 30.831013] Restarting system.
Both cameras have labels written V 5.4.3_160902 .
I flash firmware :
IPC_R6_EN_STD_5.3.8_151224 - digicap package error!!!ret=-1
IPC_R6_EN_STD_5.4.0_160401 - digicap package error!!!ret=-1
IPC_R6_EN_STD_5.5.0_170725 - Ok
IPC_R6_EN_STD_5.5.82_190220 - Ok
Result - BOOTLOOP
boards:195277
ENET freq: 50000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
Hit Ctrl+u to stop autoboot: 2
Hit Ctrl+u to stop autoboot: 1
Hit Ctrl+u to stop autoboot: 0
Formatting ............................................................................................................................................................................................................ done!
[ INFO][MIN]TFTP: TFTP from server 192.168.1.128
[ INFO][MIN]TFTP: Filename: 'digicap.dav'
[ INFO][MIN]TFTP: ################################################################################
[ INFO][MIN]TFTP: Download File
[OK][ INFO][MIN]BURN: File size is 33322648 bytes (32541 KB)
[ INFO][MIN]BURN: Writing Flash
[ INFO][MIN]BURN: ..............................................................................................................
[ INFO][MIN]BURN: Write Flash
[OK] UPDATE COMPLETE
BusyBox v1.2.1 Protect Shell (psh)
Enter 'help' for a list of davinci system commands.
# help
Support Commands:
taskShow printPart prtHardInfo
getPreviewStatus setIp setV6ip
setGateway dspStatus outputClose
outputOpen getDebug setDebug
debugLog getIrstate getMtu
camCmd getCamVer getIrstate
getLux getMcuInfo getMotion
getRawdata setIrcmd setRectFrame
updateCamera setLaserMode getLaserMode
setIrMode getIrMode setBaiguangMode
getBaiguangMode setYTLock InquireFanSwitch
StartLaser CloseLaser LaserMotReset
EnlargeCur ReduceCur SetCur
LaserMotDirect LaserTeleOffset LaserWideOffset
InqSwitch InqCurrent InqCurMotDirect
getMcuStateInfo setFastFocus getTrackStatus
getSelfcheckResult setLdcMode getLdcMode
getPreviewStatus appCmd camCmd
ezoomlens_start_t2_test prtLensCurve getLensCurve
getIp gdbcfg {Test1}
{Test2} {Test3} {Test4}
{TestN} {TestY} getIsp
getISP getisp setIsp
setISP setisp regread
regwrite setAgingMode getAgingMode
setAgingTime getAgingTime setLensZoomPos
getLensZoomPos dm365 ss
showKey showServer showUpnp
showStatus showDefence setLBS
setAlarm cloudService t1
ifconfig netstat ping
ping6 top iostat
mpstat ps reset
dmesg exit getDateInfo
diagnose help
i try command in terminal setenv bootargs console=ttyS0 debug=9 single KRN_PRT=pri
boards:195277
ENET freq: 50000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
dev_modelS-2CD2542FWD-IS
|RCV UDP pack timeout|
nand booting ...
load kernel...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.10.73+ (zhangjianzhong@Cpl-Frt-BSP) (gcc ?? 4.8.2 20130902 (prerelease) (crosstool-NG - Ambarella Linaro Multilib GCC [CortexA9 & ARMv6k] 2013.09) ) #12 PREEMPT Thu Jul 20 11:10:40 CST 2017
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: Ambarella S2L (Flattened Device Tree), model: Ambarella S2LM Kiwi Board
[ 0.000000] dev type:0x2218
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] Ambarella: AHB = 0xe0000000[0xe0000000],0x01000000 0
[ 0.000000] Ambarella: APB = 0xe8000000[0xe8000000],0x01000000 0
[ 0.000000] Ambarella: PPM = 0x00000000[0xdfe00000],0x00200000 9
[ 0.000000] Ambarella: AXI = 0xf0000000[0xf0000000],0x00030000 0
[ 0.000000] Ambarella: DRAMC = 0xdffe0000[0xef000000],0x00020000 0
[ 0.000000] Ambarella: DBGBUS = 0xec000000[0xec000000],0x00200000 0
[ 0.000000] Ambarella: DBGFMEM = 0xee000000[0xee000000],0x01000000 0
[ 0.000000] Ambarella: IAVMEM = 0x07000000[ ],0x09000000
[ 0.000000] Ambarella: FBMEM = 0x06800000[ ],0x00000000
[ 0.000000] On node 0 totalpages: 28160
[ 0.000000] free_area_init_node: node 0, pgdat 807d48f8, node_mem_map 80805000
[ 0.000000] Normal zone: 220 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 28160 pages, LIFO batch:7
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 27940
[ 0.000000] Kernel command line: console=ttyS0 debug=9 KRN_PRT=pri KRN_PRT=pri
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 110MB = 110MB total
[ 0.000000] Memory: 103360k/103360k available, 9280k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 k
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 k
[ 0.000000] vmalloc : 0x87000000 - 0xff000000 (1920 M
[ 0.000000] lowmem : 0x80000000 - 0x86e00000 ( 110 M
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 M
[ 0.000000] .text : 0x80008000 - 0x80502750 (5098 k
[ 0.000000] .init : 0x80503000 - 0x80793bd4 (2627 k
[ 0.000000] .data : 0x80794000 - 0x807dc690 ( 290 k
[ 0.000000] .bss : 0x807dc690 - 0x808002b0 ( 144 k
[ 0.000000] NR_IRQS:240
[ 0.000000] sched_clock: 32 bits at 54MHz, resolution 18ns, wraps every 79536ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [ttyS0] enabled
[ 0.273236] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 0.332603] pid_max: default: 32768 minimum: 301
[ 11.131854] Mount-cache hash table entries: 512
[ 11.138813] CPU: Testing write buffer coherency: ok
[ 11.143981] Setting up static identity map for 0x803cbe08 - 0x803cbe78
[ 11.153914] devtmpfs: initialized
[ 11.158414] pinctrl core: initialized pinctrl subsystem
[ 11.163956] NET: Registered protocol family 16
[ 11.169132] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 11.176521] L310 cache controller enabled
[ 11.180556] l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32020000, Cache size: 131072 B
[ 11.189946] ambarella-pinctrl e8009000.pinctrl: Ambarella pinctrl driver registered
[ 11.197958] ambarella-gpio gpio.0: Ambarella GPIO driver registered
[ 11.205761] read dev-tree[misc_ctrl_pin] pro [rst_time] error!
[ 11.211600] read dev-tree[misc_ctrl_pin] pro [rst_delay] error!
[ 11.220033] bio: create slab <bio-0> at 0
[ 11.225099] ambarella-dma e0005000.dma: Ambarella DMA Engine
[ 11.232755] ambarella-i2c e8003000.i2c: Ambarella I2C adapter[0] probed!
[ 11.239733] Advanced Linux Sound Architecture Driver Initialized.
[ 11.246570] Switching to clocksource ambarella-cs-timer
[ 11.258309] ambarella-sd e0002000.sdmmc0: Slot0 use bounce buffer[0x86720000<->0x06920000]
[ 11.266623] ambarella-sd e0002000.sdmmc0: Slot0 req_size=0x00020000, segs=32, seg_size=0x00020000
[ 11.275495] ambarella-sd e0002000.sdmmc0: Slot0 use ADMA
[ 11.351907] ambarella-sd e0002000.sdmmc0: 1 slots @ 50000000Hz
[ 11.357884] NET: Registered protocol family 2
[ 11.363138] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[ 11.370104] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 11.377577] TCP: Hash tables configured (established 1024 bind 1024)
[ 11.384001] TCP: reno registered
[ 11.387219] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 11.393067] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 11.399494] NET: Registered protocol family 1
[ 11.404157] RPC: Registered named UNIX socket transport module.
[ 11.410060] RPC: Registered udp transport module.
[ 11.414801] RPC: Registered tcp transport module.
[ 11.419484] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 11.624254] msgmni has been set to 201
[ 11.629318] NET: Registered protocol family 38
[ 11.633930] io scheduler noop registered
[ 11.637836] io scheduler deadline registered
[ 11.642144] io scheduler cfq registered (default)
[ 11.647677] e8005000.uart: ttyS0 at MMIO 0xe8005000 (irq = 9) is a ambuart
[ 11.655453] brd: module loaded
[ 11.661103] loop: module loaded
[ 11.667010] ambarella-nand e0001000.nand: in ecc-[1]bit mode
[ 11.672698] ambarella_nand: Use On Flash BBT
[ 11.677020] NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit), 128MiB, page size: 2048, OOB size: 64
[ 11.689248] Bad block table found at page 65472, version 0x03
[ 11.695168] Bad block table found at page 65408, version 0x03
[ 11.701059] nand_read_bbt: bad block at 0x0000002e0000
[ 11.706205] nand_read_bbt: bad block at 0x000004040000
[ 11.711407] 16 ofpart partitions found on MTD device amba_nand
[ 11.717239] Creating 16 MTD partitions on "amba_nand":
[ 11.722404] 0x000000000000-0x000000020000 : "bst"
[ 11.727868] 0x000000020000-0x000000120000 : "bld"
[ 11.733285] 0x000000120000-0x000000200000 : "ptb"
[ 11.738590] 0x000000200000-0x000000280000 : "env"
[ 11.743984] 0x000000280000-0x000000380000 : "sysflg"
[ 11.749600] 0x000000380000-0x000000400000 : "param"
[ 11.755204] 0x000000400000-0x000000500000 : "dpt"
[ 11.760555] 0x000000500000-0x000000f00000 : "rcvy"
[ 11.766080] 0x000000f00000-0x000001700000 : "krn_pri"
[ 11.771793] 0x000001700000-0x000001f00000 : "krn_sec"
[ 11.777603] 0x000001f00000-0x000004100000 : "app_pri"
[ 11.783449] 0x000004100000-0x000006300000 : "app_sec"
[ 11.789169] 0x000006300000-0x000006900000 : "cfg_pri"
[ 11.794912] 0x000006900000-0x000006f00000 : "cfg_sec"
[ 11.800590] 0x000006f00000-0x000007700000 : "dbg"
[ 11.806012] 0x000007700000-0x000007f00000 : "syslog"
[ 11.812159] ambarella-spi e0020000.spi: SPI[0] uses DMA
[ 11.817520] ambarella-spi e0020000.spi: Ambarella spi controller 0 created.
[ 11.824723] tun: Universal TUN/TAP device driver, 1.6
[ 11.829755] tun: © 1999-2004 Max Krasnyansky <[email protected]>
[ 11.891852] libphy: Ambarella MII Bus: probed
[ 11.896206] mdio_bus e000e000.etherne: /ahb@e0000000/ethernet@e000e000/phy@0 has invalid PHY address
[ 11.905337] mdio_bus e000e000.etherne: scan phy phy at address 0
[ 11.912832] mdio_bus e000e000.etherne: registered phy phy at address 0
[ 11.919353] ambarella-eth e000e000.ethernet: Ethernet PHY[0]: 0x001cc816!
[ 11.926655] ambarella-eth e000e000.ethernet: MAC Address[a4:14:37:5c:7a:bb].
[ 11.933800] PPP generic driver version 2.4.2
[ 11.938246] PPP BSD Compression module registered
[ 11.942969] PPP Deflate Compression module registered
[ 11.948172] mousedev: PS/2 mouse device common for all mice
[ 14.951864] ambarella-i2c e8003000.i2c: No ACK from address 0xa2, 0:0!
[ 14.958734] ambarella-rtc e8015000.rtc: rtc core: registered rtc-ambarella as rtc0
[ 14.966419] pcf85163 is not exist.
[ 14.969801] i2c /dev entries driver
[ 14.973823] ambarella-wdt e800c000.wdt: Ambarella Watchdog Timer Probed.
[ 14.981150] Netfilter messages via NETLINK v0.30.
[ 14.985971] nf_conntrack version 0.5.0 (1615 buckets, 6460 max)
[ 14.992258] ip_tables: © 2000-2006 Netfilter Core Team
[ 14.997597] TCP: cubic registered
[ 15.000925] NET: Registered protocol family 10
[ 15.006290] ip6_tables: © 2000-2006 Netfilter Core Team
[ 15.011716] sit: IPv6 over IPv4 tunneling driver
[ 15.016978] NET: Registered protocol family 17
[ 15.021483] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 15.029158] ThumbEE CPU extension supported.
[ 15.034590] ambarella-rtc e8015000.rtc: setting system clock to 2106-02-07 06:28:15 UTC (4294967295)
[ 15.043828] ALSA device list:
[ 15.046780] No soundcards found.
[ 15.052888] Freeing unused kernel memory: 2624K (80503000 - 80793000)
init started: BusyBox v1.19.3 (2017-07-20 11:10:26 CST)
[ 15.646644] UBI: attaching mtd10 to ubi1
[ 15.736836] UBI: scanning is finished
[ 15.751056] UBI: attached mtd10 (name "app_pri", size 34 Mi to ubi1
[ 15.760284] UBI: PEB size: 131072 bytes (128 Ki, LEB size: 126976 bytes
[ 15.767135] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 15.773839] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 15.780689] UBI: good PEBs: 271, bad PEBs: 1, corrupted PEBs: 0
[ 15.786598] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 15.793721] UBI: max/mean erase counter: 841/222, WL threshold: 4096, image sequence number: 871084521
[ 15.803009] UBI: available PEBs: 0, total reserved PEBs: 271, PEBs reserved for bad PEB handling: 9
[ 15.812052] UBI: background thread "ubi_bgt1d" started, PID 271
UBI device number 1, total 271 LEBs (34410496 bytes, 32.8 Mi, available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 Ki
[ 15.833586] UBIFS: background thread "ubifs_bgt1_0" started, PID 276
[ 15.859857] UBIFS: recovery needed
[ 15.912672] UBIFS: recovery completed
[ 15.916526] UBIFS: mounted UBI device 1, volume 0, name "app_pri"
[ 15.922677] UBIFS: LEB size: 126976 bytes (124 Ki, min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 15.931785] UBIFS: FS size: 31490048 bytes (30 MiB, 248 LEBs), journal size 1523712 bytes (1 MiB, 12 LEBs)
[ 15.941429] UBIFS: reserved for root: 1487352 bytes (1452 Ki
[ 15.947262] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 7E5D4477-3FA9-4CAA-8A56-AF37F226493F, small LPT model
[ 15.970368] UBI: attaching mtd12 to ubi3
[ 15.989785] UBI: scanning is finished
[ 16.003569] UBI: attached mtd12 (name "cfg_pri", size 6 Mi to ubi3
[ 16.009909] UBI: PEB size: 131072 bytes (128 Ki, LEB size: 126976 bytes
[ 16.019443] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 16.026209] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 16.033085] UBI: good PEBs: 48, bad PEBs: 0, corrupted PEBs: 0
[ 16.038893] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 16.046018] UBI: max/mean erase counter: 7542/5942, WL threshold: 4096, image sequence number: 1159182107
[ 16.055567] UBI: available PEBs: 0, total reserved PEBs: 48, PEBs reserved for bad PEB handling: 10
[ 16.064611] UBI: background thread "ubi_bgt3d" started, PID 280
UBI device number 3, total 48 LEBs (6094848 bytes, 5.8 Mi, available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 Ki
[ 16.086115] UBIFS: background thread "ubifs_bgt3_0" started, PID 285
[ 16.112668] UBIFS: recovery needed
[ 16.129970] UBIFS: recovery completed
[ 16.133875] UBIFS: mounted UBI device 3, volume 0, name "cfg_pri"
[ 16.139995] UBIFS: LEB size: 126976 bytes (124 Ki, min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 16.149132] UBIFS: FS size: 3047424 bytes (2 MiB, 24 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 16.158425] UBIFS: reserved for root: 143937 bytes (140 Ki
[ 16.164080] UBIFS: media format: w4/r0 (latest is w4/r0), UUID D703E8B0-C688-43A6-9DF7-BC0102AC4A13, small LPT model
[ 16.189822] UBI: attaching mtd13 to ubi4
[ 16.209212] UBI: scanning is finished
[ 16.212882] probe_rst_pin exceed
[ 16.226382] UBI: attached mtd13 (name "cfg_sec", size 6 Mi to ubi4
[ 16.235491] UBI: PEB size: 131072 bytes (128 Ki, LEB size: 126976 bytes
[ 16.242336] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 16.249013] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 16.255882] UBI: good PEBs: 48, bad PEBs: 0, corrupted PEBs: 0
[ 16.261690] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 16.268811] UBI: max/mean erase counter: 2704/1632, WL threshold: 4096, image sequence number: 2001898068
[ 16.278358] UBI: available PEBs: 0, total reserved PEBs: 48, PEBs reserved for bad PEB handling: 10
[ 16.287398] UBI: background thread "ubi_bgt4d" started, PID 290
UBI device number 4, total 48 LEBs (6094848 bytes, 5.8 Mi, available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 Ki
[ 16.308855] UBIFS: background thread "ubifs_bgt4_0" started, PID 295
[ 16.336151] UBIFS: recovery needed
[ 16.354071] UBIFS: recovery completed
[ 16.357926] UBIFS: mounted UBI device 4, volume 0, name "cfg_sec"
[ 16.364082] UBIFS: LEB size: 126976 bytes (124 Ki, min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 16.373208] UBIFS: FS size: 3047424 bytes (2 MiB, 24 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 16.382497] UBIFS: reserved for root: 143937 bytes (140 Ki
[ 16.388139] UBIFS: media format: w4/r0 (latest is w4/r0), UUID ACFAF1FC-D283-4D13-AF3F-903A6CB6F424, small LPT model
[ 16.453068] net eth0: adv: sym 1, asym: 1
[ 16.457239] net eth0: lp: sym: 0, asym: 0
[ 16.461299] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.451629] dsp: module license 'Proprietary' taints kernel.
[ 18.457596] net eth0: lp: sym: 1, asym: 1
[ 18.461592] libphy: e000e000.etherne:00 - Link is Up - 100/Full
[ 18.469685] Disabling lock debugging due to kernel taint
[ 18.475088] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 18.515461] img: IMG KERN VIRT: WR [0x87329000, 184 KB], RD [0x84750000, 36 KB].
[ 18.624619] amba_debug_init 248:248.
[ 18.842188] base module init.
[ 18.857870] [ kernel version: svn-300837 ]
[ 18.866805] mmc0 power register success!
[ 18.870755] mmc1 power register success!
[ 18.874740] request sd[mmc1] power ctrl pin error!
[ 18.879511] usb0 power register success!
[ 18.899359] usbcore: registered new interface driver usbfs
[ 18.912914] usbcore: registered new interface driver hub
[ 18.921674] usbcore: registered new device driver usb
[ 18.932535] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 18.945260] ehci-ambarella: AMBARELLA-EHCI Host Controller driver
[ 18.951533] ambarella-ehci e0018000.ehci: EHCI Host Controller
[ 18.957514] ambarella-ehci e0018000.ehci: new USB bus registered, assigned bus number 1
[ 18.965738] ambarella-ehci e0018000.ehci: irq 39, io mem 0xe0018000
[ 18.993516] ambarella-ehci e0018000.ehci: USB 2.0 started, EHCI 1.00
[ 18.999938] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 19.006892] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 19.014119] usb usb1: Product: EHCI Host Controller
[ 19.018977] usb usb1: Manufacturer: Linux 3.10.73+ ehci_hcd
[ 19.024541] usb usb1: SerialNumber: AmbUSB
[ 19.031349] hub 1-0:1.0: USB hub found
[ 19.040446] hub 1-0:1.0: 2 ports detected
mmap returns 0x76a45000
loading /home/firmware/orccode.bin...addr = 0x76a45000, size = 0x171cca
loading /home/firmware/orcme.bin...addr = 0x76d45000, size = 0x51644
loading /home/firmware/default_binary.bin...addr = 0x76de5000, size = 0x40000
infd read End
Unix bus 0 .
version: 5.10.2 [20:30:33-Jul 18 2017]
Last Changed Rev: 299284
Last Changed Date: 2017-07-14 17:00:38 +0800 (Fri, 14 Jul 2017)
shared memory address is: 0x76c5a000, sizeof(DEVICECONFIG) = 959848
[01-01 00:00:24][pid:546][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 00:00:24][pid:553] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[01-01 00:00:24][pid:553][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 00:00:24][pid:553][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 00:00:25][pid:546][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 00:00:25][pid:553] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[01-01 00:00:25][pid:553][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 00:00:25][pid:553][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 00:00:26][pid:546][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 00:00:26][pid:553] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[01-01 00:00:26][pid:553][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 00:00:26][pid:553][UNI_IF][ERROR]communicaite_to_davinci failed!!!
Unix bus End
shared memory address is: 0x76934000, sizeof(DEV_CAPABILITY) = 258664
[01-01 00:00:27][pid:567][HW_IF][ERROR]sec info get inval!!!
[01-01 00:00:27][pid:567][SYSINIT][ERROR]hwif_getsecinfo failed.
[01-01 00:00:27][pid:567][SYSINIT][ERROR]sys app init failed to reboot!
[01-01 00:00:27][pid:546][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 00:00:27][pid:553] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[01-01 00:00:27][pid:553][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 00:00:27][pid:553][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 00:00:28][pid:546][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 00:00:28][pid:553] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[01-01 00:00:28][pid:553][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 00:00:28][pid:553][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[ 29.731041] ambarella-wdt e800c000.wdt: ambarella_wdt_shutdown @ 4.
[ 29.737339] Restarting system.
on dmesg camera response
# dmesg
Linux version 3.10.73+ (zhangjianzhong@Cpl-Frt-BSP) (gcc ?? 4.8.2 20130902 (prerelease) (crosstool-NG - Ambarella Linaro Multilib GCC [CortexA9 & ARMv6k] 2013.09) ) #1 PREEMPT Wed May 25 11:46:31 CST 2016
dev type:0x2218
Ambarella: IAVMEM = 0x06800000[ ],0x09800000
On node 0 totalpages: 26112
free_area_init_node: node 0, pgdat 805d19e8, node_mem_map 805f3000
Normal zone: 204 pages used for memmap
Normal zone: 26112 pages, LIFO batch:7
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 25908
Kernel command line: console=ttyS0 dbg=0 IP=192.0.0.64 MASK=255.255.255.0 GW=0.0.0.0 SERVER=192.0.0.128 MS_ACTION=auto_update
Memory: 102MB = 102MB total
Memory: 97352k/97352k available, 7096k reserved, 0K highmem
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0x86800000 - 0xff000000 (1928 MB)
lowmem : 0x80000000 - 0x86600000 ( 102 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80381cc4 (3560 kB)
.init : 0x80382000 - 0x8059ce54 (2156 kB)
.data : 0x8059e000 - 0x805d20c0 ( 209 kB)
.bss : 0x805d20c0 - 0x805ee9e0 ( 115 kB)
NR_IRQS:240
Setting up static identity map for 0x802a1608 - 0x802a1678
cfg80211: Calling CRDA to update world regulatory domain
msgmni has been set to 190
alg: No test for stdrng (krng)
Freeing unused kernel memory: 2152K (80382000 - 8059c000)
base module init.
hikio: module license 'Proprietary' taints kernel.
init hikio.
UBI: attached mtd10 (name "app_pri", size 34 MiB) to ubi1
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: user volume: 0, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 846/225, WL threshold: 4096, image sequence number: 1527447547
UBI: available PEBs: 258, total reserved PEBs: 13, PEBs reserved for bad PEB handling: 9
UBI: background thread "ubi_bgt1d" started, PID 54
UBIFS: default file-system created
UBIFS: background thread "ubifs_bgt1_0" started, PID 61
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: reserved for root: 1487352 bytes (1452 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID E586DDEF-42A9-49A9-9573-D2FA3785C156, small LPT model
UBI: attaching mtd11 to ubi2
UBI: attached mtd11 (name "app_sec", size 34 MiB) to ubi2
UBI: good PEBs: 272, bad PEBs: 0, corrupted PEBs: 0
UBI: max/mean erase counter: 46/29, WL threshold: 4096, image sequence number: 538709095
UBI: available PEBs: 258, total reserved PEBs: 14, PEBs reserved for bad PEB handling: 10
UBI: background thread "ubi_bgt2d" started, PID 67
UBIFS: background thread "ubifs_bgt2_0" started, PID 74
UBIFS: mounted UBI device 2, volume 0, name "app_sec"
I'm not good at Linux, but soldering and reading or writing nand is not a problem for me. I read 128Mb nand if need i hawe dump. Camera need only in local network without cloud. Can someone help with advice on how to launch cameras . Thank you and sorry for my english.
I'd speculate that the bootpara data in the security chip is corrupt.
The 'magic number' "SWKH" is not found.
Perhaps someone has been attempting to modify it and triggered the in-built protection.
This is a fatal error, causing a reboot.
Code:
text:0012C722 loc_12C722                              ; CODE XREF: hwif_getsecinfo+42?j
.text:0012C722                 LDR             R3, [SP,#0x120+s] ; We read the data into SP offset up by 0x10
.text:0012C724                 LDR             R2, =0x484B5753 ; "SWKH"
.text:0012C726                 CMP             R3, R2
.text:0012C728                 BEQ             loc_12C73C ; So far, so good. Magic number OK.
.text:0012C72A                 LDR             R3, =aHwif_getseci_0 ; "hwif_getsecinfo"
.text:0012C72C                 MOVS            R0, #2
.text:0012C72E                 MOVS            R1, #0x26
.text:0012C730                 LDR             R2, =aHardwareifR_10 ; "hardwareif/r6_s2lm/core/coreinfo.c"
.text:0012C732                 STR             R3, [SP,#0x120+var_120]
.text:0012C734                 LDR             R3, =aSecInfoGetInva ; "sec info get inval!!!\n"
.text:0012C736                 STR             R3, [SP,#0x120+var_11C]
.text:0012C738                 MOVS            R3, #0xCD
.text:0012C73A                 B               loc_12C75A
Did you buy them as 'previously used' ?
Reactions: DrGEM and fenderman
I bought them as non-working. I connected the analyzer with the ISO7816 plugin to IC marked as VS16 and didn’t understand anything from the communication protocol, if it helps I can write Saleae session and send it. It is possible to run them ?
IC marked as VS16
Is that this chip?
From what I understand, they have an in-built erase function when tampered with.
It's not something I have any knowledge of.
Is that this chip?
- Yes
I only connect analyzer i do not write on chip
It is possible to somehow get around this problem , and start camera, may be custom firmware or other solution?
- Yes
If it is the EMV chip - it is possible. But it's a pain and you'll need a fair bit of knowledge about how these cameras work from a software perspective.
I think you said you don't know much linux. How are you on software reversing?
I have a G0 camera the EMV chip has been security tripped. Still works but a fair amount of work is required to bypass it. Though in G0 cameras case the kernel will reboot before davinci ever runs if it is not happy about the EMV chip. Your logs show it's davinci rebooting the camera which makes me wonder if it's the related mtd partition data instead.
Yes it me when playing around with it.
Yes works normally.
I had a copy of the encrypted data provided from the EMV > Kernel > hikcomm.ko so I patched the kernel to not talk to the EMV chip at all (which would cause a reboot), and simply return the expected encrypted data to hikcomm.ko when it asks.
Reactions: alastairstevenson
That does sound quite fiddly.
But a bit of a challenge.
It sounds like you have a working repack for the kernel. I've never quite managed that. Yet.
Well I had a spare camera to play with back in Feb 2016 (the 24th according to my notes!) and wanted to figure out how it was all working before it was publicly known. I knew there was some risk if I prodded it enough but I was OK with that :)
Just made a fun little challenge to get it working again but was already looking at that part of the security so didn't take long to fix.
But for someone not already familiar with linux, reversing, kernel etc it would be very hard with a steep learning curve I would expect.
I can't see "Card authentication succeeded" in the dmesg posted.
I've recently replaced my R6 with a G3 camera and don't have stock R6 dmesg to hand.
Does someone with an R6 want to check dmesg to see if it is supposed to be there? If yes then this appears to confirm an EMV chip issue. Perhaps R6 responds differently to an EMV chip failure or does it at a later stage (triggered by davinci).
I am too lazy to decompile the related files to check.
I think it should be after I quickly checked the kernel.
Plus this is a BIG delay in the posted dmesg:
Code:
Pretty sure this should have "Card authentication succeeded" during that time which is presumably silently failing and unlike G0 kernel doesn't immediately cause a reboot.
This from a DS-2CD2T42WD which is also a Kiwi board :
Code:
[    0.000000] dev type:0x0
[    0.000000] Ambarella:   IAVMEM = 0x06800000[          ],0x09800000
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 25908
[    0.000000] Kernel command line: console=ttyS0 KRN_PRT=pri
[    0.000000] Memory: 102MB = 102MB total
[    0.000000] Memory: 95392k/95392k available, 9056k reserved, 0K highmem
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0x86800000 - 0xff000000   (1928 MB)
[    0.000000]     lowmem  : 0x80000000 - 0x86600000   ( 102 MB)
[    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
[    0.000000]       .text : 0x80008000 - 0x804fb2cc   (5069 kB)
[    0.000000]       .init : 0x804fc000 - 0x8077b71c   (2558 kB)
[    0.000000]       .data : 0x8077c000 - 0x807b69a0   ( 235 kB)
[    0.000000]        .bss : 0x807b69a0 - 0x807d94a8   ( 139 kB)
[    0.230913] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[    0.292603] pid_max: default: 32768 minimum: 301
[    1.755116] Card authentication succeeded
[    1.759180] Mount-cache hash table entries: 512
[    1.765882] CPU: Testing write buffer coherency: ok
[    1.771057] Setting up static identity map for 0x803c20c0 - 0x803c2118
Yes as I thought - should take about 1.45 seconds to communicate to the EMV chip to get the encrypted params. This doesn't happen successfully in OPs dmesg and why it doesn't work (and takes almost 11 seconds to fail).
OP did send me the mtd dump of the camera and the params mtd partition looks correct.
Ok i connect ic to smart card reader and is responding in Smart Card ToolSet PRO Demo
SMART CARD
TYPE NAME .................... ISO-7816 Smart Card
ICC STATE
ATR STRING ................... 3B 6D 00 00 68 6B 00 08 20 0A 19 24 33 07 54 00 74
ICC PRESENCE ................. 2
ICC INTERFACE STATUS ......... 255
ICC TYPE PER ATR ............. 1
CURRENT IO STATE ............. < no info >
PROTOCOL
DEFAULT DATA RATE ............ 10753
MAX DATA RATE ................ 344086
ASYNC PROTOCOL TYPES ......... 3
DEFAULT CLK .................. 4000
MAX CLK ...................... 4000
MAX IFSD ..................... 254
SYNC PROTOCOL TYPES .......... < no info >
IFD PROTOCOL
CURRENT PROTOCOL TYPE ........ 1
CURRENT CLK .................. 4000
CURRENT F .................... 372
CURRENT D .................... 1
CURRENT N .................... 0
CURRENT W .................... 10
CURRENT IFSC ................. 0
CURRENT IFSD ................. 254
CURRENT BWT .................. 0
CURRENT CWT .................. 0
CURRENT EBC ENCODING ......... 0
EXTENDED BWT ................. < no info >
How to interrogate a chip to find out if it answers correctly, what software need?
Well you can use available tools to decrypt the firmware, then unpack the kernel, then decompile it to find the communication protocol keys and methods. The link already posted above might have the correct keys, or maybe not I never checked on my R6.
Just bear in mind the kernel running on the camera is already doing that and failing. Perhaps there was a hardware error that resoldering and checking the traces would resolve but if it is an EMV chip problem then you are likely out of luck. I'm not aware anyone outside Hikvision has written to these chips.
Given you have 2 of these cameras with the same fault (and from same source?) then it sounds like someone was messing around with them implying this is not a hardware fault. In that case patching the camera software seems the only remaining option.
That is log without EMV Chip (I desolder it)
boards:195277
ENET freq: 50000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
|NUL eth|
nand booting ...
load kernel...
[ 0.000000] vmalloc : 0x87000000 - 0xff000000 (1920 MB)
[ 0.000000] lowmem : 0x80000000 - 0x86e00000 ( 110 MB)
[ 0.000000] .text : 0x80008000 - 0x80502750 (5098 kB)
[ 0.000000] .init : 0x80503000 - 0x80793bd4 (2627 kB)
[ 0.000000] .data : 0x80794000 - 0x807dc690 ( 290 kB)
[ 0.000000] .bss : 0x807dc690 - 0x808002b0 ( 144 kB)
[ 0.273250] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 14.700456] Mount-cache hash table entries: 512
[ 14.707407] CPU: Testing write buffer coherency: ok
[ 14.712576] Setting up static identity map for 0x803cbe08 - 0x803cbe78
[ 14.722526] devtmpfs: initialized
[ 14.727025] pinctrl core: initialized pinctrl subsystem
[ 14.732562] NET: Registered protocol family 16
[ 14.737738] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 14.745132] L310 cache controller enabled
[ 14.749132] l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32020000, Cache size: 131072 B
[ 14.758555] ambarella-pinctrl e8009000.pinctrl: Ambarella pinctrl driver registered
[ 14.766569] ambarella-gpio gpio.0: Ambarella GPIO driver registered
[ 14.774366] read dev-tree[misc_ctrl_pin] pro [rst_time] error!
[ 14.780204] read dev-tree[misc_ctrl_pin] pro [rst_delay] error!
[ 14.788596] bio: create slab <bio-0> at 0
[ 14.793705] ambarella-dma e0005000.dma: Ambarella DMA Engine
[ 14.801333] ambarella-i2c e8003000.i2c: Ambarella I2C adapter[0] probed!
[ 14.808314] Advanced Linux Sound Architecture Driver Initialized.
[ 14.815152] Switching to clocksource ambarella-cs-timer
[ 14.826855] ambarella-sd e0002000.sdmmc0: Slot0 use bounce buffer[0x86720000<->0x06920000]
[ 14.835173] ambarella-sd e0002000.sdmmc0: Slot0 req_size=0x00020000, segs=32, seg_size=0x00020000
[ 14.844043] ambarella-sd e0002000.sdmmc0: Slot0 use ADMA
[ 14.920487] ambarella-sd e0002000.sdmmc0: 1 slots @ 50000000Hz
[ 14.926466] NET: Registered protocol family 2
[ 14.931727] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[ 14.938693] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 14.946167] TCP: Hash tables configured (established 1024 bind 1024)
[ 14.952588] TCP: reno registered
[ 14.955806] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 14.961654] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 14.968089] NET: Registered protocol family 1
[ 14.972750] RPC: Registered named UNIX socket transport module.
[ 14.978651] RPC: Registered udp transport module.
[ 14.983390] RPC: Registered tcp transport module.
[ 14.988073] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 15.191161] msgmni has been set to 201
[ 15.196223] NET: Registered protocol family 38
[ 15.200821] io scheduler noop registered
[ 15.204727] io scheduler deadline registered
[ 15.208989] io scheduler cfq registered (default)
[ 15.214562] e8005000.uart: ttyS0 at MMIO 0xe8005000 (irq = 9) is a ambuart
[ 15.222350] brd: module loaded
[ 15.227988] loop: module loaded
[ 15.233892] ambarella-nand e0001000.nand: in ecc-[1]bit mode
[ 15.239537] ambarella_nand: Use On Flash BBT
[ 15.243898] NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit), 128MiB, page size: 2048, OOB size: 64
[ 15.256130] Bad block table found at page 65472, version 0x03
[ 15.262051] Bad block table found at page 65408, version 0x03
[ 15.267941] nand_read_bbt: bad block at 0x0000002e0000
[ 15.273088] nand_read_bbt: bad block at 0x000004040000
[ 15.278290] 16 ofpart partitions found on MTD device amba_nand
[ 15.284143] Creating 16 MTD partitions on "amba_nand":
[ 15.289273] 0x000000000000-0x000000020000 : "bst"
[ 15.294761] 0x000000020000-0x000000120000 : "bld"
[ 15.300106] 0x000000120000-0x000000200000 : "ptb"
[ 15.305480] 0x000000200000-0x000000280000 : "env"
[ 15.310867] 0x000000280000-0x000000380000 : "sysflg"
[ 15.316477] 0x000000380000-0x000000400000 : "param"
[ 15.322083] 0x000000400000-0x000000500000 : "dpt"
[ 15.327438] 0x000000500000-0x000000f00000 : "rcvy"
[ 15.332959] 0x000000f00000-0x000001700000 : "krn_pri"
[ 15.338672] 0x000001700000-0x000001f00000 : "krn_sec"
[ 15.344476] 0x000001f00000-0x000004100000 : "app_pri"
[ 15.350253] 0x000004100000-0x000006300000 : "app_sec"
[ 15.356043] 0x000006300000-0x000006900000 : "cfg_pri"
[ 15.361775] 0x000006900000-0x000006f00000 : "cfg_sec"
[ 15.367451] 0x000006f00000-0x000007700000 : "dbg"
[ 15.372867] 0x000007700000-0x000007f00000 : "syslog"
[ 15.378965] ambarella-spi e0020000.spi: SPI[0] uses DMA
[ 15.384392] ambarella-spi e0020000.spi: Ambarella spi controller 0 created.
[ 15.391564] tun: Universal TUN/TAP device driver, 1.6
[ 15.396594] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 15.460432] libphy: Ambarella MII Bus: probed
[ 15.464786] mdio_bus e000e000.etherne: /ahb@e0000000/ethernet@e000e000/phy@0 has invalid PHY address
[ 15.473918] mdio_bus e000e000.etherne: scan phy phy at address 0
[ 15.481409] mdio_bus e000e000.etherne: registered phy phy at address 0
[ 15.487930] ambarella-eth e000e000.ethernet: Ethernet PHY[0]: 0x001cc816!
[ 15.495233] ambarella-eth e000e000.ethernet: MAC Address[a4:14:37:5c:7a:bb].
[ 15.502377] PPP generic driver version 2.4.2
[ 15.506825] PPP BSD Compression module registered
[ 15.511548] PPP Deflate Compression module registered
[ 15.516757] mousedev: PS/2 mouse device common for all mice
[ 18.520444] ambarella-i2c e8003000.i2c: No ACK from address 0xa2, 0:0!
[ 18.527314] ambarella-rtc e8015000.rtc: rtc core: registered rtc-ambarella as rtc0
[ 18.534998] pcf85163 is not exist.
[ 18.538380] i2c /dev entries driver
[ 18.542398] ambarella-wdt e800c000.wdt: Ambarella Watchdog Timer Probed.
[ 18.549724] Netfilter messages via NETLINK v0.30.
[ 18.554545] nf_conntrack version 0.5.0 (1615 buckets, 6460 max)
[ 18.560837] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 18.566178] TCP: cubic registered
[ 18.569506] NET: Registered protocol family 10
[ 18.574867] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 18.580293] sit: IPv6 over IPv4 tunneling driver
[ 18.585561] NET: Registered protocol family 17
[ 18.590067] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 18.597743] ThumbEE CPU extension supported.
[ 18.603175] ambarella-rtc e8015000.rtc: setting system clock to 1970-01-01 00:06:05 UTC (365)
[ 18.611796] ALSA device list:
[ 18.614747] No soundcards found.
[ 18.620856] Freeing unused kernel memory: 2624K (80503000 - 80793000)
[ 19.216289] UBI: attaching mtd10 to ubi1
[ 19.306319] UBI: scanning is finished
[ 19.320604] UBI: attached mtd10 (name "app_pri", size 34 MiB) to ubi1
[ 19.327030] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 19.336547] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 19.343315] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 19.350166] UBI: good PEBs: 271, bad PEBs: 1, corrupted PEBs: 0
[ 19.356085] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 19.363212] UBI: max/mean erase counter: 847/225, WL threshold: 4096, image sequence number: 1527447547
[ 19.372587] UBI: available PEBs: 0, total reserved PEBs: 271, PEBs reserved for bad PEB handling: 9
[ 19.381631] UBI: background thread "ubi_bgt1d" started, PID 271
UBI device number 1, total 271 LEBs (34410496 bytes, 32.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 19.403217] UBIFS: background thread "ubifs_bgt1_0" started, PID 276
[ 19.429615] UBIFS: recovery needed
[ 19.446874] UBIFS: recovery completed
[ 19.450778] UBIFS: mounted UBI device 1, volume 0, name "app_pri"
[ 19.456901] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 19.466039] UBIFS: FS size: 31490048 bytes (30 MiB, 248 LEBs), journal size 1523712 bytes (1 MiB, 12 LEBs)
[ 19.475680] UBIFS: reserved for root: 1487352 bytes (1452 KiB)
[ 19.481509] UBIFS: media format: w4/r0 (latest is w4/r0), UUID E586DDEF-42A9-49A9-9573-D2FA3785C156, small LPT model
[ 19.504681] UBI: attaching mtd12 to ubi3
[ 19.523995] UBI: scanning is finished
[ 19.537670] UBI: attached mtd12 (name "cfg_pri", size 6 MiB) to ubi3
[ 19.546792] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 19.553644] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 19.560323] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 19.567194] UBI: good PEBs: 48, bad PEBs: 0, corrupted PEBs: 0
[ 19.573016] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 19.580126] UBI: max/mean erase counter: 7548/5945, WL threshold: 4096, image sequence number: 1414869433
[ 19.589675] UBI: available PEBs: 0, total reserved PEBs: 48, PEBs reserved for bad PEB handling: 10
[ 19.598719] UBI: background thread "ubi_bgt3d" started, PID 280
[ 19.620198] UBIFS: background thread "ubifs_bgt3_0" started, PID 285
[ 19.646789] UBIFS: recovery needed
[ 19.664070] UBIFS: recovery completed
[ 19.667930] UBIFS: mounted UBI device 3, volume 0, name "cfg_pri"
[ 19.674093] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 19.683223] UBIFS: FS size: 3047424 bytes (2 MiB, 24 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 19.692512] UBIFS: reserved for root: 143937 bytes (140 KiB)
[ 19.698154] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 8821894F-0E84-416B-986C-2E5ED4BB3460, small LPT model
[ 19.724027] UBI: attaching mtd13 to ubi4
[ 19.743393] UBI: scanning is finished
[ 19.757098] UBI: attached mtd13 (name "cfg_sec", size 6 MiB) to ubi4
[ 19.766225] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 19.773075] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 19.779753] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 19.786617] probe_rst_pin exceed
[ 19.789833] UBI: good PEBs: 48, bad PEBs: 0, corrupted PEBs: 0
[ 19.795655] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 19.802775] UBI: max/mean erase counter: 2710/1636, WL threshold: 4096, image sequence number: 716144162
[ 19.812234] UBI: available PEBs: 0, total reserved PEBs: 48, PEBs reserved for bad PEB handling: 10
[ 19.821275] UBI: background thread "ubi_bgt4d" started, PID 290
[ 19.842866] UBIFS: background thread "ubifs_bgt4_0" started, PID 295
[ 19.869814] UBIFS: recovery needed
[ 19.887601] UBIFS: recovery completed
[ 19.891494] UBIFS: mounted UBI device 4, volume 0, name "cfg_sec"
[ 19.897612] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 19.906744] UBIFS: FS size: 3047424 bytes (2 MiB, 24 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 19.916033] UBIFS: reserved for root: 143937 bytes (140 KiB)
[ 19.921684] UBIFS: media format: w4/r0 (latest is w4/r0), UUID B93366D6-35F0-4110-A497-72412EDE5D14, small LPT model
starting pid 298, tty '': '-/bin/psh'
BusyBox v1.2.1-171136 Protect Shell (psh)
Interesting!
No EMV chip - no reboot.
But it's never going to work without the bootpara data the chip provides, without some clever hacking to provide by a patched method.
I'm wondering if it's booted into recovery.
Though it looks a bit complete for recovery - though I've not seen an R6 series recovery anyway so I'm not sure.
(By the way - it's easier for us to read if you enclose the logs in the CODE tags - and for something big you can then also enclose them in the SPOILER tags as you have been doing.)
I was thinking you could try the MCR modded 5.4.5 that skips psh, but I suspect you'd get caught by the rollback block, even with the update command at the bootloader, as the 5.5.82 has been loaded.
Attached anyway.
It would give more chances to experiment.
Reactions: DrGEM
