As the title says my Qvis/Oyn-x Falcon NVR has died.
They are still available to purchase but I would prefer to purchase something more up to date and possibly from a better manufacturer. To view the NVR on the network you have to use an Active x plug in with Internet Explorer although SuperLive Plus is fine for remote access.
My NVR has eight cameras but I am not using the built in POE sockets, but instead using a POE hub so that I can assign a local IP address to each camera so they are accessible to Home Assistant smart home software. I therefore do not need an NVR with POE sockets.
Are there any NVRs made by Reolink, HikVision, Dahua or similar more well known companies that will work with my Qvis cameras. I understand that not all IP cameras can be connected to newer IP NVRs. I've included Bullet camera specs and attached the spec for turret and current NVR
Any advice would be much appreciated.
