looney2ns
Thats what I was thinking could be done. A 4/4 POE port in the shop and another one in the house for the house cameras. Then the single Cat5e cable running underground to the house router which connects the 2 PoE ports. I attached a diagram.
Also, whats the issue with the Dahua "international version" versus the other when using Blue Iris? Ive read issues about firmware upgrade problems, but is it only for non-Blue Iris or OMVIF? Is there a reason to steer cler wit hthis setup?
You want the International version cams from Dahua. The other you refer to are China Region cams, and those can't usually be upgraded along with other issue's.
So, any cams you think about purchasing, be sure you can find the exact model number on the: http://www1.dahuasecurity.com/
Otherwise they are probably China Region cams, which you don't want. Those are what you typically find on Amazon or Ebay.
This has nothing to do with BI.
And as David said, you want Gigabyte capable switches.
