My NVR setup is on the way from Andy... just getting in some research ahead of time
Through searching the forum I understand that the POE switch built into the NVR will technically hand out IP addresses different from the Local LAN ip scheme to each camera.
I understand that is how you want it to be for security reasons etc...
My question is could you hypothetically change the built in switch for everything to match schemes with your local network, or would it create a conflict since the NVR POE is essentially acting like a router itself?
