- Aug 11, 2017
- 22
- 0
I'm planning on migrating away from BI 5 on a Windows 10 box with six cameras, mostly Reolink 10 Mpixel. I set the video to max resolution and 10 frames per second. Key frame interval is 10-20.
Old box is Intel i7-377K with 16 Gbyte RAM, 1 Gbyte C drive (Seagate 1HH162), 6 Tbyte D drive (OOS6000G). I can't find much about this last drive other than it's sort of related to Seagate). Mixed success with this setup. A lot of times, it just stops recording in the middle of some event. I realize this is my problem, not BI's. I hope.
New will be AMD Ryzen 7 5800X (X570 AORUS Master, 8 cores) with 32 Gbyte RAM, 1 Gbyte C drive (WD_BLACK SN750) and <TBD> storage drives.
Options are Linux with <something> DVR or Windows 11 and BI 6.
My primary question is about BI 6 and how it handles video storage drives. I have the ability to install up to 3 WD_PURPLE disks. WD_PURPLE is available in 2, 4, 8, 6, 12, 18 Gbyte sizes with prices to match. I would prefer several smaller drives over one large drive. Eggs in one basket sort of thing.
With multiple drives, is there still this deal where there's a primary drive with something periodically moving old video clips to secondary drive(s)?
The X570 is supposed to support RAID on some subset of SATA connectors. Can I create a motherboard RAID for storage? I know how RAID works but my experience is with hardware controller boards, not the motherboard stuff.
If not using RAID, can I set up BI with one storage disk, say 4 GByte, and add more later if needed without having to completely re-design the install?
Related to storage, I've had poor experience with what BI records and am leaning twards having it record for longer periods which of course will mean more storage. I need to figure out a happy medium between non-stop recording vs event triggered. Non-stop is not a very attractive option but at least I'll get ALL of any event. If I can ever find it
Speaking of triggering, It's been my practice to turn off everything I can inside the camera and let BI do all that needs to be done. No on-screen displays, triggers, zones, time syncs, etc. I think I'm getting BI to use the second stream to detect stuff and then, when triggered, record using the first stream but there's a lot that I don't understand here.
Thanks for any comments
