I'm essentially a novice IP Cam guy. I have an older Hikvision DS-2CD752MF that when I view it locally in RTSP in VLC player it plays smoothly as expected.
When viewed locally in Blue Iris, it pauses every 10 seconds for 2 seconds. You have smooth video 10 seconds, it pauses, you see its time stamp stop, then it jumps ahead about 2 second. Rinse, repeat.
And not particularly important, when viewed in IP Cam Viewer over a 4g connection, it does consistent pauses and jumps every couple seconds. Very squirrely.
Other Foscams I have on the network run smooth and as well as a Foscam would be expected to run in all applications. Go figure... :-/
I figure if VLC can view it smoothly, it's in a setting I've done in Blue Iris maybe? Or potentially a setting in the cam that BI just doesn't appreciate? Any thoughts/advice?
Thanks much!
Thanks much!
