I get good results with a Bosch 7000 Starlight NBN-71013 box camera, an IR-corrected Tamron M13VG850IR lens, and a very powerful and directional long-range IR emitter (CMVision IR200, easy to find on Ebay or Amazon).  I'll attach a couple samples at about 150ft range.  Getting these lenses may be a little bit of a scavenger hunt, just watch Ebay for that exact model and be aware there are non-IR-corrected variants of it.  The Bosch camera can accommodate non-IR-corrected lenses by maintaining separate motorized backfocus locations for day and night modes, if you have to settle for a non-IR version.
The Bosch is "only" a 720p cam but has good low-light performance that allows it to stay at 1/1000th shutter speed at night, plus enough granularity to dial the settings for usable plate pictures.  If you did get one, you'll need to do some tuning of the ALC (exposure, basically) to get the results you need.  In general, I lower ALC to almost as low as it goes, and reduce temporal noise filtering far enough to eliminate ghosting.  I also have the big-brother Bosch 8000 Starlight and they are nice overall, but I still consider my 7000 the best one in my rack for day/night LPR.
Whatever you get, lock shutter speed to a high speed to keep blur under control, and if possible, put the camera up high, so headlights don't aim right up the camera lens and swamp your plate reflectivity.  Alternately, if you want to run the IR emitter 24 hours a day, you could put some IR-pass polycarbonate in front of the camera lens, filtering out most visible light and leaving plate reflection at a strong advantage.  I haven't tried this in a daytime scenario since my camera's high enough to ride over the top of low-beam headlights.
