Question on IVS and SMD difference between them and applications
Daniele
Jan 14, 2017
12
4
Hello,
I have recently bought a Dahua NVR NVR4416-4KS2/I along with a couple of IP camera HFW3441T-ZS. Both are equipped with IVS and SMD Plus.
First of all I have noticed that in the camera SMD Plus is enabled by default.
The reason why I am asking for help is because it is not clear to me the difference between IVS and SMD.
I know that SMD has been developed to identify humans and vehicles filtering false alarms due weather and pets. I also know the thanks to IVS you can define some rules, like tripwire and intrusions that generate alarms.
What is not clear to me is when IVS has to be used and on the contrary when SMD has to be used instead of IVS. In what application/context it is better to use an ISV rule and in what one it is better to rely on SMD?
Secondly it is not clear to me if ISV can work together SMD or not.
I have started defining some ISV rules in the NVR and they seem to work even if sometimes I get a false alarm due to a cat wandering around. So my doubt is, could I filter some false alarms that's to SMD together ISV?
Thanks for helping,
Daniele
For most IVS is better. It allows better granular level setup and processing.
You also want to take the cameras off of auto/default settings in order to get the most success from the AI.
You want to do one or the other. Using IVS and SMD will cause issues.
See this thread from just this week where we discuss the two:
Reactions: Daniele
IVS and SMD are fairly similar and can achieve similar results. They both have their pros and cons, but I would agree with wittaj that IVS tripwires are generally the most useful.
In my experience doing troubleshooting for Dahua OEM cameras using IVS and SMD simultaneously is perfectly ok. In fact, one configuration I find useful is if you want to configure several different periods during the day to receive notifications. For instance, if you wanted to get notifications from your gate all day to see if anyone was entering the property, but only notifications on your yard at night because your kids play there during the day. There is no way to do this with just one method, as you can only define one schedule per notification type.
In general, IVS is better for monitoring certain pathways and property lines. SMD is a good catch-all if you want to see what's going on all the time, or don't want to bother configuring IVS. The AI IVS rules will also categorize humans and vehicles, there isn't much of a difference there.
Either is fine, I would start with one and see what your results are. Then you might want to fine-tune it or switch.
Reactions: Brekel and Daniele
You can also set up mutliple IVS rules and schedule per IVS rule to accomplish this.
It seems that there's some disagreement re SMD vs/plus IVS. (See previous discussion on this site).
So it's OK to have both? I've now got just one rule in IVS: intrusion.
And in SMD, it's Enabled ('AI by Camera'), high sensitivity, human only checked. This has been like this all along, but hasn't fixed the constant false alarms. The other thing that's maddening, is that because there is a significant pre-detection delay, I have to wait an eternity to discover that nothing was detected. That is, a false alarm... It's never ending.
As I said in your other thread (and best not to start asking same questions in multiple threads as that is how people will go silent on you).
If you want false triggers, then by all means continue using MD/SMD right @bigredfish LOL.
If you want to eliminate false triggers, then use IVS. When you get advanced features, that your NVR probably doesn't have, then you use IVS in the camera for accurate triggers and the metadata in the NVR for other features.
Here was a hot thread with some banter back and forth. Read for yourself and tell me if you think MD/SMD is superior to IVS
Sorry, wasn't thinking of other threads. I'm old... And thanks for clarification re IVS, etc. If you or someone can direct me to a useful manual, I'll bite the bullet and invest the time to work this stuff out for myself. But thanks for the help.
And this is another great thread:
I pointed to the Dahua wiki in your other thread. You can search and read until you fall asleep LOL.
