Question on auto tracking with DH-SD6CE445XA-HNR
missel
May 13, 2020
9
3
FRANCE
Hello,
First, sorry for my poor English.
Second, I don't know if I am in the good section to expose my needs.
I bought a DH-SD6CE445XA-HNR, very good product.
Very big thank to IPCAMTALK cause I found the way to setup the auto tracking.
I would like to do something but I don't know if it's possible.
I try to explain :
I set up
3 presets (Preset1; Preset2; Preset3). Preset3 is opposite view of Preset1 and Preset2 is a view in the middle of preset1 view and preset3 view.
3 Smart plan
3 IVS with 2 separates intrusions zones for each preset
The default position is Preset1
If an intrusion appears in this Preset1, the auto tracking is working through the 3 presets (not always but let say is working !!). After the 300 sec the camera come back to Preset1.
I would like when an intrusion happens in Preset3, that the camera "turns" from Preset1 to Preset3 and records the events.
Is it possible ?
If yes, how to do it ?
Add info :
I never found the solution to operate the tripewire.
The only type of rule is working is Intrusion.
Thanks in advance for your help and advice.
Missel
For the IVS setting, you can refer to @Wildcat_1 review about the SD5A425XA-HNR.
