Question & Suggestion to NVR manufacturers: Why don't NVRs have a special NIC Ethernet port that allows you to access the cameras web interface directly? For example, it would be nice if my HikVision DS-7608NI-I2/8P had:
Right now I must unplug a camera then use that POE port to connect my computer to access the remaining cameras via its internal NIC addresses. This is pain-in-the-you-know-what! Especially if your NVR is not easily accessible.
EDIT: See @fenderman and @alastairstevenson virtual host solution to this below.
- 8 POE camera ports;
- 1 LAN Ethernet port; and
- 1 NIC Ethernet port.
