Question about Smartwares CIP-39220 IP Cam
klokklok
Apr 3, 2019
3
1
Netherlands
I bought a Smartwares CIP-39220 IP Cam and its not that great so far. It only works on Android/IOS devices by default and the app (SW360) requires to have access to the Media and Location of my device. Also the cam doesn't work on a local network and requires internet access (to a Chinese server) to even display the video stream, this seems like a big security issue.
Because of the problems described above I tried to find the RTSP stream (or any other protocol) to get the cam working on just my local network.
The quality of the Cam is pretty good (1080p) in day and even night conditions.
Some info about the IP Cam:
Ports: 80, 64444 (Sadly no FTP or Telnet)
Firmware version: 2.0.27.0
The network paths I discovered so far:
Single image path: 192.168.1.115:80/snapshot.jpg (640x360)
RTSP Stream: rtsp://192.168.1.115:80/ch1_0.264 (Sadly requires a username/password which I don't have)
Bubble Stream: http://192.168.1.115:80/bubble/live?ch=0&stream=0 (Also requires username/password for handshake)
The API the cam is talking to: openapi.dvr163.com (Located in China)
I found a lot of use full information in this Github repository: github.com/maxious/c8915a436b532ab09e61bf937295a5d2
Its not exactly the same Cam but the software seems identical.
Does anyone have experience with bad IP Cams like this or even the software its running on? The only further step I know is Brute forcing the RTSP username/password and disabling full internet connection for the cam. But I'm not sure if that is the right step.
Edit: Trying to use plain text instead of the Github URL Because the page is huge.
Reactions: Theos
Hi have the same Ip camera, sniffing the network with wireshark I've found the RTSP authentification data:
user: admin
pass: ca3fee3d
Sadly it seem's that the stream doesn't work with VLC
Reactions: klokklok
Hi all,
Just connected the same camera to my network and try to figure out my password. I stared to some wireshark-dumps all night, but it doesn't make too much sense yet. I don't like the connections to China at all, and would love to use the rtsp-stream instead.
@Bdom17: could you please share with us how you where able to recover the password?
@klokklok, the github-links seems to be down, would it be possible to share the info with me?
Thanks!
Reactions: klokklok
Hi all,
Thanks!
Hi,
The connections to China are terrible and I also wanna manage the camera on my own.
Here is the Github page I found by searching on google for: "ipcam port 80 64444"
This forum just loads the full page, that is the reason why I removed it from my original post. I couldn't find a way to post a normal link.
Try to find a firmware dump for those cameras and run it through strings and Ghidra to see what endpoints are offered. I did this for my "Sannce"/Annke cameras and created a camera control script based on what I found:
github: Cam controls cameras, or is supposed to
While your camera probably differs in some respects there tend to be many similarities due to the way these companies copy code from each other and elsewhere. Here's a list of endpoints found on my (Xiongmai-produced) cameras, check the web source and my script to see how it is used:
Bash:
# based on strings pulled from firmware dump, these represent api endpoints
# used with GET or PUT requests as defined in NK_N1Device_InitV2()
# check http://camera_ip/js/function.js (etc) for how these endpoints seem to expect
# to be fed amd cared for - "seem" because the firmware is quite buggy and not all
# endpoints seem to be connected.
# /NetSDK/
# /NetSDK/Audio/encode/channel
# /NetSDK/Audio/encode/channel/[id=101]
# /NetSDK/Audio/encode/channel/[id=101]/enabled
# /NetSDK/Audio/input/channel
# /NetSDK/Audio/input/channel/[id=1]
# /NetSDK/Audio/input/channel/[id=1]/inputVolume
# /NetSDK/Audio/input/channel/[id=1]/microphoneType
# /NetSDK/Audio/input/channel/[id=1]/outputVolume
# /NetSDK/Audio/input/channel/[id=1]/sampleBitWidth
# /NetSDK/Audio/input/channel/[id=1]/sampleRate
# /NetSDK/Factory
# /NetSDK/Image
# /NetSDK/Image/denoise3d
# /NetSDK/Image/irCutFilter
# /NetSDK/Image/manualSharpness
# /netsdk/image/videoMode
# /NetSDK/Image/videoMode
# /NetSDK/Image/wdr
# /NetSDK/Network/DNS
# /NetSDK/Network/ESee
# /NetSDK/Network/interface
# /NetSDK/Network/interface/[id=1]
# /NetSDK/Network/interface/[id=1]/lan
# /NetSDK/Network/interface/[id=4]
# /NetSDK/Network/interface/[id=4]/lan
# /NetSDK/Network/interface/[id=4]/wireless
# /NetSDK/Network/port
# /NetSDK/Network/port/[id=1]
# /NetSDK/Network/wireless/allStaInfo
# /NetSDK/Network/wireless/stationSignal
# /NetSDK/Network/Wireless/status
# /NetSDK/PTZ/channel/[id=1]/control
# /NetSDK/snapshot
# /NetSDK/snapshot.jpg
# /NetSDK/System/deviceInfo
# /NetSDK/System/deviceInfo/deviceAddress
# /NetSDK/System/deviceInfo/deviceName
# /NetSDK/System/operation
# /NetSDK/System/operation/default
# /NetSDK/System/operation/reboot
# /NetSDK/System/operation/remoteUpgrade
# /NetSDK/System/time
# /NetSDK/System/time/calendarStyle
# /NetSDK/System/time/localTime
# /NetSDK/System/time/ntp
# /NetSDK/System/time/rtc
# /NetSDK/System/time/timeZone
# /NetSDK/Video/encode/channel
# /NetSDK/Video/encode/channel/101/snapshot
# /NetSDK/Video/encode/channel/102/snapshot
# /NetSDK/Video/encode/channel/[id=101]
# /NetSDK/Video/encode/channel/[id=101]/channelNameOverlay
# /NetSDK/Video/encode/channel/[id=101]/datetimeOverlay
# /NetSDK/Video/encode/channel/[id=101]/requestKeyFrame
# /NetSDK/Video/encode/channel/[id=102]
# /NetSDK/Video/encode/channel/[id=102]/requestKeyFrame
# /NetSDK/Video/encode/channel/[id=1]/requestKeyFrame
# /NetSDK/Video/encode/channel/[id=2]/requestKeyFrame
# /NetSDK/Video/input/channel
# /NetSDK/Video/input/channel/[id=1]
# /NetSDK/Video/input/channel/[id=1]/brightnessLevel
# /NetSDK/Video/input/channel/[id=1]/contrastLevel
# /NetSDK/Video/input/channel/[id=1]/flipEnabled
# /NetSDK/Video/input/channel/[id=1]/hueLevel
# /NetSDK/Video/input/channel/[id=1]/mirrorEnabled
# /NetSDK/Video/input/channel/[id=1]/PrivacyMask
# /NetSDK/Video/input/channel/[id=1]/saturationLevel
# /NetSDK/Video/input/channel/[id=1]/sharpnessLevel
# /NetSDK/Video/motionDetection/channel
# /NetSDK/Video/motionDetection/channel/[id=1]
# /cgi-bin/gw2.cgi
# /cgi-bin/hi3510/echo.cgi
# /cgi-bin/hi3510/ptzctrl.cgi
# /cgi-bin/hi3510/preset.cgi
# /cgi-bin/hi3510/param.cgi
# /livestream/11
# /livestream/12
# /livestream/hinetate/11
# /livestream/hinetate/12
# /snapshot
# /snapshot.jpg
# /user/add_user.xml
# /user/del_user.xml
# /user/set_pass.xml
# /user/user_list.xml
# /_SDK/index.php
# /_SDK/info/device.php
# /_SDK/info/event.php
# /_SDK/info/license.php
# /_SDK/info/monitor.php
RTSP Stream: rtsp:/192.168.1.115:80/ch1_0.264 (Sadly requires a username/password which I don't have)
Bubble Stream: (Also requires username/password for handshake)
Did you ever had any luck with getting rtsp to work, i supose you got the at Action
I have a yeskamo cam and i need to get into the cam using the web pages built into it,
You cant just go to the ip it wants more detail about the logon page path and/or page name
I read all of the above and tried some guesses to no avail
the following urls will NOT result in a 404 not found, which may be a clue for an expert to guess what the logon page path and or name is
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<user ver="1.0" you="" add_user="no" ret="sorry" mesg="check in falied"/>
