Hello Team!!
I have the following devices:
NVR: DS-7616NI-K2 - firmware V4.74.200 build 230522
Cameras: DS-2CD2343G2-IU - firmware V5.7.13 build 230706
I have SD cards in all my cameras as well and ANR function is enabled. For now everything is okay. The problem/issue that i am facing is the fact that a week ago one of my cameras lost connectivity for some reason( the issue was in the switch, because when i restart it everything is working). The camera power was not lost and the recording was stored on the SD card. When i checked the playback from the NVR i can see the ANR(it is mark as green - command triggered) in the event but it is only continues. It is recording 24/7 without stopping. This means that for the past week that the camera was network disconnected i have only for the last 24 hours the recordings(everything from the other 6 days is gone because it was overwritten).
My question is - is there a specific settings for the ANR to record on events? Now i think it is set up to continues 24/7 but i am not if or where this could be changed.
Now with this settings it is recording only events - human, vehicle and motion events which is perfect. But with if the ANR is recording 24/7 it is lets say not in use very well because the recording is reduced to only 1 day... and if it is on events only it will record maybe a week. Thank you in advance for all the suggestions.
These are the settings from the NVR :
These are the settings from the camera:
