I am looking to add cameras to my new home.
I have CAT5e cables planned for POE cams already run to 2 locations at the front of my house and 2 locations in the back all 4 under soffits.
The front faces the not too busy street.
I also plan to get a few cameras for inside the house.
After some research, it seems like recommendations are for turrets over domes, 1/1.8" large sensors, and medium MP for low light viewing such as 4MP instead of 8MP.
This has led me to the IPC-T5442T-ZE which I see on Amazon:
https://www.amazon.com/EmpireTech-IPC-T5442T-ZE-Vari-Focal-Eyeball-Starlight/dp/B08LCY27TD/ref=sr_1_2?m=A329YQ83EBQGJF&marketplaceID=ATVPDKIKX0DER&qid=1624331495&redirect=true&s=merchant-items&sr=1-2
I am looking for general clear view of my front and back yards in both day and night 24/7 recording.
Goals are general surveillance and smart notifications so I am not alerted to moving trees. Reading license plates in the front would be a good bonus, but if it would cost a lot more it is not required.
1. Would you agree this specific camera would be a good fit for my situation or is there another model at this price or lower that you would think is better?
I also saw the Dahua N45DJ62 that seems to be similar to this 5442 model, but the N45DJ62 seems to have a fixed 2.8mm focal length.
I considered turrets for the back and then maybe bullets for the front, but I'm not sure if that would be better or not than all 4 being the same turrets.
2. What NVR would you suggest? Should it be a Dahua NVR to match these cameras? If so, which model?
I was thinking 8 channel so I can connect the 4 outside cams and have room for up to 4 inside the house.
I don't think I want to go down the Blue Iris route, but I did just order hardware to setup a QNAP NAS which includes QVR Pro/Surveillance Station if that would be better than a dedicated NVR.
3. What indoor camera models do you suggest?
My ethernet jacks are only behind a few high tv mount locations. None at the baseboards around ankle height around the house. For this reason, would you suggest wifi indoor cams instead of POE?
I read in the CliffsNotes thread about the Amcrest IP4M-1051B and Hikvision/Annke 151DR. Would one of those be best for this situation?
Thank You in advance!
