Little by little I'm planning for my IP camera install and have another question.
I did some research and it seems that RJ45 plugs are the least reliable type of termination and accepted practices dictate to terminate the in-wall wiring at a punchdown, then use a patch cable from there.
I see a lot of people here use rack mounted punch down panels but I am severely limited on space in the closet and don't think I can fit it (unless there is a wall mount option?).
Is the next best thing to use wall plates with keystones? My wires will be coming in from the ceiling in the closet.
I want to avoid using plugs on the in wall wiring (except probably at the cameras) and am looking to clean up my existing rats next of BNC cables and not replicate it with Ethernet.
Thanks!
ps: I'd share a pic of the existing mess but would probably get banned
Thanks!
