You might also try to fix that by after finishing all the configuration make the NVR connect to the cameras with a non-administrator account![]()
Ahh yes, I did try this. But for some reason it would not record. I gave up on it after failing to get it right for a few days. All I did was add a non-administrator account on the camera and then in the NVR go to the cameras and edit it to connect with the new user/pass. If it's something that is a known work around for this issue I'll persist with that a little more but I thought it was just another thing that was just not quite right. Have you been able to get the NVR to record when using a non-admin user Securame? It was odd because from memory, I could still see live view... so the video feed was available. It would not record on motion/event though.
