- Mar 14, 2018
- 21
- 0
I have a Qcam system installed, POE cameras wired to the NVR the kit came with. Is it possible to replace the NVR with a POE switch and PC running Blue Iris? Will those Qcam cameras function fine without the NVR they came with? Do they need to be flashed with different firmware?
This is the Qcam system:
https://amcrest.com/qcam-3mp-8-channel-nvr-4-poe-bullet-ip-cameras-554.html
Thanks for your input!
