greetings - i have a qc824-4p4-1 nvr with 4 POE wired cams still in the boxes to set up & would like to know if i can add 1 or more wireless IP cams on the network to the unit & record it, or if i would have to remove wired cams to make room? the manuals aren't clear about it. i'm guessing that it wont run & record more than 4 cams, but want to know for sure so i can think about getting something different that will do more.
thanks
update -
q-see online chat timed me out before the above post, but on my 2nd try they answered my question that the unit can't record more than 4 cams at once
this place is very informative so maybe the q-see gets returned & i'll use what i learn here to buy some cams & run blueIris
thanks
update -
