- Jan 17, 2017
- 16,205
- 27,175
Hi,
I was attempting to find more information on EZVIZ branded IP PoE NVRs and Cameras. Unfortunately, so far I have not found the detailed spec sheets I prefer to use to compare the spec. ( I was looking for ONVIF data on the EZVIZ IP PoE NVRs and Cameras )
As EZVIZ iirc is a Hikvision owned brand, the question I have are the EZVIZ IP PoE NVRs and cameras compatible with Hikvision OEM NVRs and Cameras. That is can one w/configuration setting changes get the Hikvision cameras to function on the EZVIZ NVR or get the EZVIZ IP PoE cameras to function with a Hikvision OEM NVR?
Example of a recent deal which prompted me to inquire:
8 Channel HD 1080p PoE IP NVR Security System w/ 2TB HDD and 4 Weatherproof 1080p PoE Bullet IP Cameras, Works with Alexa and Google Home Using IFTTT (BN-1824A2)
https://flash.newegg.com/Product/81-389-013EZVIZ
