Pygmy goats live stream
nejakejnick
Aug 30, 2015
140
25
Camera: Hikvision DS-2CD2032-I
Unfortunately, I will not be able to run this indefinitely, as it consumes about 25% of i5-3570k@4,5GHz + 30% of GTX770 (1920x1080 4096kbps 15fps).
I need to find a way how to stream without re-encoding - to some provider...
[video]https://www.youtube.com/channel/UCr_u0Vrln-My9a91eY7_XsA/live[/video]
Just watched a little one squeeze into the big tire and now you can barely see his ear :)
I just found that I can use NVENC hardware encoder on NVIDIA GPU, it reduces CPU usage of XSplit to 10%. :rolleyes: I could maybe buy a GT 720 to my BI PC and stream indefinitely. I currently use SSH reverse tunnel to my personal PC and stream from there...
One thing I am not happy is the quality of video at night, that i-frame is quite disturbing, not sure if perhaps more IR illumination would help...
And it seems to me that the video lags a little bit frequently, could it be caused by recording in 15 fps and reencoding to 30fps for youtube, or the 25ms latency between my PC with XSplit and the camera. or it looks fine to you?
edit: I think it has something to do with the network, I saw clearly that the time was slowed down, and then several seconds of the video quickly played in one real time second.:(
