Hi All,
I have been using Postman to try to use a PUT to enable/disable Line Detection in a DS-2CD2132F-IS with the following:
http://ID:password@IP:Port/smart/linedetection
I send the following XML:
<LineDetectionList version="1.0" xmlns="Oops:The page you are visiting may have been deleted,renamed or inaccessible.">
<enabled>false</enabled>:
</LineDetectionList>:
I haven't been able to change from true to false, even though I get a return success message. I'm not sure what is wrong. I am using the camera's admin account with Remote Parameter Settings enabled. Postman is inserting the colons that you see twice in the code above.
Any advice would be greatly appreciated.
