1 105437 BIT Beta Team Jun 8, 2015 2,163 1,054 May 16, 2023 #1 Anyone else seeing these errors in the BI log file? Push: failed ffffff96 to My_iPhone; check security exemptions and service Login
S SpacemanSpiff Known around here Apr 15, 2021 1,714 3,200 USA May 16, 2023 #2 Push: failed 80090328 to iPhone, check security exemptions and service Login Version 5.6.5.9 Any idea what the cause / fix is for this? ipcamtalk.com Reactions: 105437
1 105437 BIT Beta Team Jun 8, 2015 2,163 1,054 May 16, 2023 #3 @SpacemanSpiff I read through the thread and didn't see anything to try. I'm getting some push notifications successfully, I just noticed this error for some attempts in my BI log for both my wife and I.
wittaj IPCT Contributor Apr 28, 2019 30,935 59,342 USA May 16, 2023 #4 You need to be on BI version 5.7.1 or newer.
1 105437 BIT Beta Team Jun 8, 2015 2,163 1,054 May 16, 2023 #5 wittaj said: You need to be on BI version 5.7.1 or newer. Click to expand... I'm on v5.7.6.7
S SpacemanSpiff Known around here Apr 15, 2021 1,714 3,200 USA May 16, 2023 #6 Is the posted error form BI server, or the mobile device?
1 105437 BIT Beta Team Jun 8, 2015 2,163 1,054 May 16, 2023 #7 From the BI log. I have rebooted the BI PC and the iPhones... seems to be working again.
