PTZ425DB-AT vs PTZ425DB-AT-R - Low Noise?
IReallyLikePizza2
2,480
5,844
Houston
I need a PTZ with zoom, so I plan on ordering a PTZ425DB-AT soon. I see the smoke lens version, the PTZ425DB-AT-R seems to suggest it has a low noise motor
Is this not present on the regular model?
@EMPIRETECANDY is the regular one also going on sale soon? I see the -R is going to be on sale soon
Thanks!
It is one of the more silent PTZs since the movement mechanism is protected by the dome. Mine kinda sounds like R2-D2 when up close to it.
Keep in mind that this camera needs a lot of light for any distance.
Reactions: JDreaming
for me classic PTZ425DB-AT is one of the loudest PTZ cams...
it generates very high frequency pitch noise (R2-D2 is good comparison :) - which moves over air at longer distances and it's very easy to determine source / direction of...
I had installed PTZ425DB-AT for some time on my home building, people from street simply stared at that PTZ when it started to move..
Finally I removed it (cctv laws in EU are much more strict, I didn't want any problems)...
Can someone (Andy @EMPIRETECANDY) confirm / deny that the new 'smoke lens' version is much more silent / have different frequency / noise type?
How much?
@EMPIRETECANDY do you know when the -R will come back in stock? I placed an order on Amazon but its out of stock
The stocks is on the way to US, 26th will arrive at Long Beach CA, and then need some days to be delivered to Amazon. So i think they can deliver to you at early April. They will ship you soon when cameras delivered.
Reactions: samplenhold
Awesome, thanks!!!
Everyone can get ready for some ultra zoomed in nonsense on my street
I can confirm that SD425DB-AT-R (stealth version of MiniPTZ) is most silent (audible) PTZ which I tested in my life.
even more silent in comparison to bigger brothers from SD5 series, which have very low frequency (bass frequencies) sounds..
I have on my desk and I almost don't hear it..
Dahua changed all motors and fans inside..
no more squishy high pitched R2-D2 sounds which normal version SD425DB-AT had..
I prefer my R2D2. It gets everyone to look up straight into the camera ;)
PTZ425DB-AT-R this one even put on desk you can't hear anthing. So can be good for some indoor business places or some place need very quiet monitoring.​
Smoke housing also make the camera direction invisiable.
