Got into the cam with explorer and added the plugin. Went thru the settings and it appears that IVS is working ok inside the cam. Reading those trigger signals in Blue Iris is a horse of a different color.
Blue Iris is set up to read the cam thru ONIVF. The triggers are reading ONIVF. Cam address is HTTP and not HTTPS.
At the bottom of the Network IP Config screen, there is an entry, two input boxes, side by side, with "00000" in each. The title for the two boxes is "ONVIF Source". ???
What's the best way to troubleshoot this?
