PTZ schedule on 4.5.3.3
Spooling
Sep 26, 2015
234
69
Is anyone having issues with the PTZ schedule on 4.5.3.3?
I can see the events listed in the messages properly, but they aren't aiming the camera.
The camera aiming works correctly if I manually select a preset through the interface.
I have the same problem, "Event Schedule" not working, after upgrade to 4.5.3.3. Had to reinstall and old update 4.5.2.0. Works fine now.
Not sure what version you had installed before this latest update. If you can find the 4.5.3.2 update that might solve your problem. Unfortunately I keep neglecting to download and save updates. Maybe someone on this forum can supply the 4.5.3.2 update, or your latest update version.
Yeah same here. I should download all the versions. If anyone's listening and can upload 4.5.3.2 somewhere that would be great.
Thanks
