PTZ preview
Ssayer
BIT Beta Team
Jan 5, 2016
19,787
71,741
SE Michigan USA
Seems simple, but... Have I been missing out all this time because I'm just not finding the setting?
In UI3, while viewing a particular camera, when I hover over a Preset, I get a little popup window with a preview of where that preset actually views.
Does BI do that with it's main console and I just can't find the setting?
Don't think that it does. The only place that I know of that shows the previews is under PTZ > Edit presets. If the box at the bottom doesn't show anything for a preset, then you can call the preset from the Call button there, click the pencil in the box edit icon at the bottom, and then it will assign that view to the preset.
Reactions: Ssayer
Yep, that much I know. I was just hoping for more because remembering what preset brings a camera where for 25 cams is a little much for this old guy. Thanks though!
