PTZ Mounting Question
amdpowered
Apr 25, 2020
83
63
USA
Can you mount the PFA120 junction box directly to brick? Or do you need to mount it to a corner mount / pole mount?
I'm thinking PFB306W -> PFA120 -> Brick wall.
I don't see why you couldn't mount it to brick. Just need tapcons or plastic anchors to fasten it. Maybe some washers if the holes in the back are too big.
Yeah you can use a masonary bit and mount the backing plate to the Brick. That's actually something I should look at for my PTZ..... Do you have to come up with 4 of your own Metric bolts to fasten the cam? or do they come in the box.
The PFB306W came with 4 sleeve anchors. I believe they are 3/8"x2". However I bought some 1/2"x2.25" sleeve anchors from home depot. They look much beefier. I'll update if / when I successfully mount it.
Reactions: sebastiantombs
Also putting this here for Google to index so people will know.
Knockout seal size for the PFA120 center hole is 1.5in. The 2in version is too large.
Reactions: Flintstone61
