Nick87080
If you have drilled holes already check to see how many are solid and how many hit a void. I'm not very good a what screws are better than others but it may help to go to hardware store and tell them how many are solid and how many are hitting the voids. let them help you pick out whats best for the weight and conditions. Take your drill bit with you that you used.
