Hello everyone!
I have a few of Mini IP PTZ HD cams, no name, with the following specs:
Kernel: Linux 2.6.18_arm_v5t_le
File System Version: TS48W-ONVIF-P2P V2.5.1.5 build 2014-08-21 19:49:17
It's some type of IPC, with TPSEE firmware / hardware ? I got them from AliExpress about a year ago.
They work good, I do like them. They run on UC2 PC software and I was able to set the to work with BlueIris just fine.
The problem:
After a power outage, all cameras came back online except one. I plugged / unplug power to it, nothing. Change power adapters - nothing.
Basically, the camera appears on the software, but there is no image. PTZ works, the night infrared don't light up. I can access the camera settings from any of the software, or the web page, I checked all ports, everything. No image at all.
I reset factory defaults, changed ports, connect directly to it, still no image, only PTZ functions work.
Any ideas, any help? I burned a module or something? Appreciate all the help / ideas!
Thank you!
The problem:
Thank you!
