If I had plywood to grab onto, would be great. I have the siding, foam insulation (4-6") blown insulation THEN the plywood.I use 1 1/2” wood deck screws into siding/ plywood for all mine. Never looked for stud. Been up for years no issues.
Hence, only have vinyl and foam to grab onto unless I can find a stud.
