Is there some guide or tutorial on how to manage cameras with PTZ positions?
I created some cameras with sensor movement, and they work, but of course, this only works for a fixed position I have set. I'm not that far yet into the exploring the changing profiles to activate or deactivate motion when they are moved or with different schedules since I'm trying to do things in baby steps.
My most basic question is: Should I set PTZ default position on Blue Iris or the camera software? Assuming if this is possible for Blue Iris. For example, I want to be able to click a default position for those cameras, and they will automatically move exactly to that position. Or make that the default when they reboot, lose power, or just when a profile is set. Basically have a default I can use for now before exploring into other settings in other positions since getting the camera exactly right to create the movement in the motion sensor is quite tricky, it would be preferred to be able to set to that position automatically.
