PTZ camera with very high zoom (100x)
kwinz
Jun 7, 2020
2
Vienna
Hi!
I am looking for a very high magnification PTZ IP camera (up to 100x or 120x) for a lookout webcam.
Does a PTZ camera like this exist? I did a bit of research but all I can find are prohibitively exepenisve military cameras.
Thanks in advance!
Hi!
Thanks in advance!
Welcome @kwinz
Try to see what Dahua or Hikvision may have in their list of products...
Dahua is here..
So far found a 48x .. perhaps that will work ??
Reactions: kwinz
The Dahua PTZ´s offer a maximum focal length of 300mm. If you really need more zoom, you could use the Fujifilm SX 800 with up to 800mm focal length and a 1/1.8 - 2mp Sensor. Long Range Surveillance Camera SX Series | Fujifilm [United States]
For PTZ Capabilities, you should use an external positioning system like the "Platon Neo" Platon® NEO - The Most Powerful PTZ Camera - made in Germany (platon-neo.com)
This will be a very reliable solution - but very expensive.
Instead of the Dahua PTZ, you could also use a hikvison one. DS-2DF8C260I5XS-AELW(T5) - Ultra Series - Hikvision
This one has a focal length of 360 mm, so higher than dahua. And much cheaper than the fujifilm
Reactions: kwinz
Univision have some PTZ camera with 92x to 120x optical zoom: Wholesale Ultra long range zoom PTZ camera factory and manufacturers | Huanyu
screenshot-2024-07-18-at-2-26-30%E2%80%AFpm-png.198828
