Hi guys,
I bought a these PTZ camera from Aliexpress.
After switching on it made selftest and started to spin itself and watch after 5 seconds 3 preset positions.
Using CMS software, I tried to bring up the OSD menu, with no result. Reset via WEB management does not work (only the hi3516drbcv100 chip settings are reset, but the camera continues to rotate).
I try to connect to the camera by Telnet, unfortunately it shows me strange characters and no possibility to enter a login etc.
I used nmap to find out the available open ports, but neither of them is able to perform a classic login. Once the camera is in that state, no control works (from web browser, CMS, or from Hik NVR)
Is there any way to bring up the OSD menu and try to reset the camera? Otherwise repair?
Thanks for your help!
Jirka
Code:
***********FrameNum: 13715*****************
***************FrameNum: 13716*****************
***************FrameNum: 13717*****************
***************FrameNum: 13718*****************
***************FrameNum: 13719*****************
***************FrameNum: 13720*****************
***************FrameNum: 13721*****************
***************FrameNum: 13722*****************
***************FrameNum: 13723*****************
***************FrameNum: 13724*****************
***************FrameNum: 13725*****************
***************FrameNum: 13726*****************
***************FrameNum: 13727*****************
***************FrameNum: 13728*****************
***************FrameNum: 13729*****************
***************FrameNum: 13730*****************
***************FrameNum: 13731*****************
***************FrameNum: 13732*****************
***************FrameNum: 13733*****************
***************FrameNum: 13734*****************
***************FrameNum: 13735*****************
***************FrameNum: 13736*****************
***************FrameNum: 13737*****************
ObjID 1228<88>: TR 0 LT 1 DT 0 ISP 0 CPU 0 [276 0 304 48]
***************FrameNum: 13738*****************
ObjID 1228<88>: TR 0 LT 2 DT 0 ISP 0 CPU 0 [276 0 302 44]
***************FrameNum: 13739*****************
ObjID 1228<88>: TR 0 LT 3 DT 0 ISP 0 CPU 0 [278 0 298 40]
ObjID 1229<90>: TR 0 LT 1 DT 0 ISP 0 CPU 0 [318 0 374 180]
***************FrameNum: 13740*****************
ObjID 1228<88>: TR 0 LT 4 DT 0 ISP 0 CPU 0 [280 0 296 34]
ObjID 1229<90>: TR 0 LT 2 DT 0 ISP 0 CPU 0 [318 0 374 178]
ObjID 1230<90>: TR 0 LT 1 DT 0 ISP 0 CPU 0 [144 0 206 182]
ObjID 1231<90>: TR 0 LT 1 DT 0 ISP 0 CPU 0 [50 28 128 200]
ObjID 1232<88>: TR 0 LT 1 DT 0 ISP 0 CPU 0 [38 166 60 192]
***************FrameNum: 13741*****************
ObjID 1229<89>: TR 0 LT 3 DT 0 ISP 0 CPU 0 [320 0 346 178]
ObjID 1230<90>: TR 0 LT 2 DT 0 ISP 0 CPU 0 [148 0 192 182]
ObjID 1231<88>: TR 0 LT 2 DT 0 ISP 0 CPU 0 [74 110 126 172]
ObjID 1232<86>: TR 0 LT 2 DT 0 ISP 0 CPU 0 [52 176 90 196]
ObjID 1233<88>: TR 0 LT 1 DT 0 ISP 0 CPU 0 [82 40 112 50]
***************FrameNum: 13742*****************
ObjID 1229<91>: TR 0 LT 4 DT 0 ISP 0 CPU 0 [320 14 340 174]
ObjID 1230<90>: TR 0 LT 3 DT 0 ISP 0 CPU 0 [148 0 190 182]
ObjID 1232<85>: TR 0 LT 3 DT 0 ISP 0 CPU 0 [54 178 86 194]
ObjID 1234<90>: TR 0 LT 1 DT 0 ISP
Code:
Starting Nmap 7.70 ( https://nmap.org ) at 2019-08-07 09:00 Stoední Evropa (letní eas)
NSE: Loaded 148 scripts for scanning.
NSE: Script Pre-scanning.
Initiating NSE at 09:01
Completed NSE at 09:01, 0.01s elapsed
Completed NSE at 09:01, 0.00s elapsed
Initiating Ping Scan at 09:01
Scanning 192.168.12.2 [4 ports]
Completed Ping Scan at 09:01, 1.79s elapsed (1 total hosts)
Initiating Parallel DNS resolution of 1 host. at 09:01
Completed Parallel DNS resolution of 1 host. at 09:01, 5.51s elapsed
Initiating SYN Stealth Scan at 09:01
Scanning 192.168.12.2 [65535 ports]
Discovered open port 80/tcp on 192.168.12.2
Discovered open port 554/tcp on 192.168.12.2
Discovered open port 8899/tcp on 192.168.12.2
Discovered open port 9570/tcp on 192.168.12.2
Discovered open port 8000/tcp on 192.168.12.2
Discovered open port 34567/tcp on 192.168.12.2
Discovered open port 9530/tcp on 192.168.12.2
Completed SYN Stealth Scan at 09:01, 5.69s elapsed (65535 total ports)
Initiating Service scan at 09:01
Scanning 7 services on 192.168.12.2
Service scan Timing: About 71.43% done; ETC: 09:04 (0:01:00 remaining)
Completed Service scan at 09:04, 161.07s elapsed (7 services on 1 host)
Initiating OS detection (try #1) against 192.168.12.2
Initiating Traceroute at 09:04
Completed Traceroute at 09:04, 3.01s elapsed
Initiating Parallel DNS resolution of 2 hosts. at 09:04
Completed Parallel DNS resolution of 2 hosts. at 09:04, 5.50s elapsed
NSE: Script scanning 192.168.12.2.
Initiating NSE at 09:04
Completed NSE at 09:05, 81.58s elapsed
Initiating NSE at 09:05
Completed NSE at 09:05, 1.12s elapsed
Nmap scan report for 192.168.12.2
Host is up (0.0011s latency).
Not shown: 65528 closed ports
PORT STATE SERVICE VERSION
80/tcp open http uc-httpd 1.0.0
|_http-favicon: Unknown favicon MD5: EC9D1C872C50DD7DA7D826D9C85FC158
|_http-title: NETSurveillance WEB
554/tcp open rtsp?
8000/tcp open http-alt?
8899/tcp open soap gSOAP 2.7
|_http-title: Site doesn't have a title (text/xml; charset=utf-8).
9530/tcp open tcpwrapped
9570/tcp open unknown
| fingerprint-strings:
| GenericLines, NULL:
| HTTPD: fd: 143, IP: 0xa4016ac
| RTP: onClientConnect enginedId 0 , clientId 0 , ip:port 172.22.64.10:3489
| ***************FrameNum: 1044501*****************
| ***************FrameNum: 1044502*****************
| ***************FrameNum: 1044503*****************
| ***************FrameNum: 1044504*****************
| ***************FrameNum: 1044505*****************
| ***************FrameNum: 1044506*****************
| ***************FrameNum: 1044507*****************
| Transprot: New Connect ID[8]@[172.22.64.10:3494]___!!!___
| ===>Connect :[objID=1] [client=8] ip[172.22.64.10:3494]
| ***************FrameNum: 1044508*****************
| ***************FrameNum: 1044509*****************
| ***************FrameNum: 1044510*****************
| ***************FrameNum: 1044511*****************
| ***************FrameNum: 1044512*****************
| ***************FrameNum: 1044513*****************
|_ ***************Fra
34567/tcp open dhanalakshmi?
1 service unrecognized despite returning data. If you know the service/version, please submit the following fingerprint at https://nmap.org/cgi-bin/submit.cgi?new-service :
SF-Port9570-TCP:V=7.70%I=7%D=8/7%Time=5D4A7746%P=i686-pc-windows-windows%r
SF:(NULL,1068,"HTTPD:\x20fd:\x20143,\x20IP:\x200xa4016ac\nRTP:\x20onClient
SF:Connect\x20enginedId\x200\x20,\x20clientId\x200\x20,\x20ip:port\x20172\
SF:.22\.64\.10:3489\x20\n\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*FrameNum:\x20\x2010
SF:44501\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*
SF:FrameNum:\x20\x201044502\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*\*\*\
SF:*\*\*\*\*\*\*\*\*\*FrameNum:\x20\x201044503\*\*\*\*\*\*\*\*\*\*\*\*\*\*
SF:\*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*FrameNum:\x20\x201044504\*\*\*\*\
SF:*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*FrameNum:\x20\
SF:x201044505\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\
SF:*\*\*FrameNum:\x20\x201044506\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*
SF:\*\*\*\*\*\*\*\*\*\*\*\*FrameNum:\x20\x201044507\*\*\*\*\*\*\*\*\*\*\*\
SF:*\*\*\*\*\*\nTransprot:\x20New\x20Connect\x20ID\[8\]@\[172\.22\.64\.10:
SF:3494\]___!!!___\n===>Connect\x20:\[objID=1\]\x20\[client=8\]\x20ip\[172
SF:\.22\.64\.10:3494\]\n\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*FrameNum:\x20\x20104
SF:4508\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*F
SF:rameNum:\x20\x201044509\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*\*\*\*
SF:\*\*\*\*\*\*\*\*\*FrameNum:\x20\x201044510\*\*\*\*\*\*\*\*\*\*\*\*\*\*\
SF:*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*FrameNum:\x20\x201044511\*\*\*\*\*
SF:\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*FrameNum:\x20\x
SF:201044512\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\*
SF:\*\*FrameNum:\x20\x201044513\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*\
SF:*\*\*\*\*\*\*\*\*\*\*\*Fra")%r(GenericLines,107A,"HTTPD:\x20fd:\x20143,
SF:\x20IP:\x200xa4016ac\nRTP:\x20onClientConnect\x20enginedId\x200\x20,\x2
SF:0clientId\x200\x20,\x20ip:port\x20172\.22\.64\.10:3489\x20\n\*\*\*\*\*\
SF:*\*\*\*\*\*\*\*\*\*FrameNum:\x20\x201044501\*\*\*\*\*\*\*\*\*\*\*\*\*\*
SF:\*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*FrameNum:\x20\x201044502\*\*\*\*\
SF:x201044503\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\
SF:*\*\*FrameNum:\x20\x201044504\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*
SF:\*\*\*\*\*\*\*\*\*\*\*\*FrameNum:\x20\x201044505\*\*\*\*\*\*\*\*\*\*\*\
SF:*\*\*\*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*FrameNum:\x20\x201044506\*\*
SF:\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*FrameNum:
SF:\x20\x201044507\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\nTransprot:\x20New\x2
SF:0Connect\x20ID\[8\]@\[172\.22\.64\.10:3494\]___!!!___\n===>Connect\x20:
SF:\[objID=1\]\x20\[client=8\]\x20ip\[172\.22\.64\.10:3494\]\n\*\*\*\*\*\*
SF:\*\*\*\*\*\*\*\*\*FrameNum:\x20\x201044508\*\*\*\*\*\*\*\*\*\*\*\*\*\*\
SF:*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*FrameNum:\x20\x201044509\*\*\*\*\*
SF:201044510\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\*
SF:\*\*FrameNum:\x20\x201044511\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*\
SF:*\*\*\*\*\*\*\*\*\*\*\*FrameNum:\x20\x201044512\*\*\*\*\*\*\*\*\*\*\*\*
SF:\*\*\*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*FrameNum:\x20\x201044513\*\*\
SF:*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\n\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*Fra");
Device type: general purpose
Running: Linux 2.6.X|3.X
OS CPE: cpe:/o:linux:linux_kernel:2.6 cpe:/o:linux:linux_kernel:3
OS details: Linux 2.6.32 - 3.10
Uptime guess: 0.488 days (since Tue Aug 06 21:22:39 2019)
Network Distance: 3 hops
TCP Sequence Prediction: Difficulty=259 (Good luck!)
IP ID Sequence Generation: All zeros
TRACEROUTE (using port 53/tcp)
HOP RTT ADDRESS
1 ...
2 1.00 ms 172.22.64.4
3 2.00 ms 192.168.12.2
NSE: Script Post-scanning.
Completed NSE at 09:05, 0.00s elapsed
Read data files from: C:\Program Files (x86)\Nmap
OS and Service detection performed. Please report any incorrect results at https://nmap.org/submit/ .
Nmap done: 1 IP address (1 host up) scanned in 277.85 seconds
Raw packets sent: 65574 (2.886MB) | Rcvd: 65612 (2.626MB)
Jirka
