PTZ cam with 25x zoom for driveway
mvanders
May 20, 2020
17
2
NY
I want to start by saying thanks to the group. I had a question earlier about a camera for a driveway and the overwhelming recommendation was for a IPC-B54IR-Z4E S3 . This was the perfect choice and has worked well. Additionally i am looking for a PTZ camera with tracking but in a smaller formfactor. I currently have a Ubiquiti unifi GTZ 6 which in ok at best, but has a great form factor. I am looking for recommendations for an IR PTZ cam that can to up to a 25x zoom but with the smallest footprint possible. This is a residence so not looking for a camera that belongs in a prison but more so something that is smaller an lend in. May be a unicorn but the group had great suggestions before, and hope you have some suggestions for this.
Thanks for your help.
Mark
This.
But as mentioned, at night you will need some good ambient light. IR is weak and it’s a 1/2.8 sensor so don’t expect great nighttime performance
If you have plenty of streetlights and you and neighbors keep driveway coach lights on it can be ok
What distances are you looking at?
