psa : Too Many Homeowners Fall For This Common HVAC Scam : The DIY HVAC Guy
mat200
17,446
29,419
make certain you have a good carbon monoxide detector
The DIY HVAC Guy
Yes, I've got one in master bedroom and one in the living room, both have PPM display. These are separate from my 2 smoke detectors.
I installed a carbon monoxide detector to safeguard against false claims of dangers like cracked heat exchangers. Great call on the detector—it’s a must for any home, especially when HVAC scams are common, as The DIY HVAC Guy points out. If you’re looking to avoid shady upsells, consider a ductless mini split air conditioning system. They’re efficient, don’t rely on traditional furnace setups, and can reduce the risk of issues like carbon monoxide leaks. Stay vigilant and keep that detector batteries fresh!
Reactions: mat200 and duplo
