I've been lurking around but have not found a definitive answer yet. I just started working with schedules and profiles and I'm still trying to understand them. I've read several threads and I'm almost there.
I have a simple setup since this is all new to me. One hk series 2132 running in BI4 latest version. I turned on the global schedule leaving profile 1 as default, 24/7. I then went to profile 2 and set it up to be active between 7am and 5pm M-F. I then went to the camera and set motion record when triggered for profile 1. I changed to profile 2 and set motion, record when triggered and alert via push to app when triggered.
What I'm assuming is when it's between 7am and 5pm M-F I will get the alerts and it will record. When its NOT 7am-5pm M-F the only difference is I won't get alerts. Is that correct?
I'm also assuming that even though profile 1 is set to be active 24/7, profile 2 take over when it is active. Is that correct?
I'm just wondering since profiles 1 and 2 overlap between 7am and 5pm M-F if I will get double recordings?
