- Dec 14, 2015
- 126
- 18
I've set up several profiles. In the BI interface, I see this:
It appears profile 1 is the default profile, but if I click the clock icon above several times, I get this:
which indicates "Standard" is the default. "Standard" is what I named profile 1.
What's the difference between the two images above??
I also see "Temp time (min)" as an option for each profile in the setup screen.
The "help" file indicates that this temp time is:
""This value represents the number of minutes for which a temporary profile selection will remain in effect. A temporary profile selection is made by clicking one of the buttons 1-7 or ~ at the top of Blue Iris window. The timer is in effect when you see the stopwatch icon to the left of the profile numbers. Click the stopwatch icon to return to normal schedule operation immediately."
What if I don't want the profile to be temporary? There doesn't seem to be a way to do that. Sometimes I may want to switch profiles for an indefinite period of time - can that be done?
Also, the profiles don't seem to be working. When I click one of the profile numbers, I get no recordings. For example Profile 2 is set up to record motion, but nothing is recorded. What am I doing wrong: (BTW, I don't have any schedules set up, nor do I want to)
