- Aug 28, 2014
- 36
- 0
I purchased 3 used Hikvision DS-2CD863F-E Cameras and have no problem installing them in Blue Iris and they work fine. Problem
is if I try to connect to them using IE (with I believe Netsurveyer) and have tried CMS also. The web page with login appears but it
appears to not being displayed properly as text do not match the position of the password entry lines. I enter user and password and
when I click on login the login Icon does not do anything. Does Hikvision use some other program. I also have a problem with my Chinese
Seculink cameras in that I can log into them fine but the Model selection on BI for Securlink does not seem to work. Will write another
thread for that.
thread for that.
