Hello,
There is something wrong with installed bullet camera. After it turns into night mode (IRs on), strange moving things like flying dust fills the image. Camera was taked stright from package plastic bag and installed, no visible dust inside camera. The rubber seal between case and front protective glass looks fine. Should I open it up and try to clean it or is that image noise possibly caused by some other reason? If I turn on IR-s, the noise is gone. Any advice, please?
With IRs on, b&w image:
IRs turned off, colour image:
Camera: Planet ICA-3250V 2MP bullet http://www.planet.com.tw/en/product/product.php?id=48587
Thanks.
Thanks.
