Hi,
I've bought a Chinese Gadinan camera: Gadinan Onvif HD 3MP 2MP 1080P IP Camera Support Audio With Built in Microphone Pickup Day Night Metal Dome Camera 2.8mm lens
I had a problem with rstp connection so I asked for help my friend. He changed the standard tcp port 34567 to 554. After that we cannot connect to the camera. It reacts for pings but I cannot login via http. I've installed nmap and got that:
Starting Nmap 7.80 ( Nmap: the Network Mapper - Free Security Scanner ) at 2019-09-19 11:05 ?rodkowoeuropejski czas letni
NSE: Loaded 151 scripts for scanning.
Initiating ARP Ping Scan at 11:05
Scanning 192.168.2.15 [1 port]
Completed ARP Ping Scan at 11:05, 0.22s elapsed (1 total hosts)
Initiating Parallel DNS resolution of 1 host. at 11:05
Completed Parallel DNS resolution of 1 host. at 11:06, 5.53s elapsed
Initiating SYN Stealth Scan at 11:06
Scanning 192.168.2.15 [65535 ports]
Discovered open port 80/tcp on 192.168.2.15
Discovered open port 554/tcp on 192.168.2.15
Discovered open port 9530/tcp on 192.168.2.15
Completed SYN Stealth Scan at 11:06, 17.53s elapsed (65535 total ports)
Initiating Service scan at 11:06
Scanning 3 services on 192.168.2.15
Completed Service scan at 11:06, 22.13s elapsed (3 services on 1 host)
Initiating OS detection (try #1) against 192.168.2.15
Retrying OS detection (try #2) against 192.168.2.15
Retrying OS detection (try #3) against 192.168.2.15
Retrying OS detection (try #4) against 192.168.2.15
Retrying OS detection (try #5) against 192.168.2.15
NSE: Script scanning 192.168.2.15.
Initiating NSE at 11:06
Completed NSE at 11:08, 86.15s elapsed
Initiating NSE at 11:08
Completed NSE at 11:08, 2.04s elapsed
Completed NSE at 11:08, 0.00s elapsed
Nmap scan report for 192.168.2.15
Host is up (0.020s latency).
Not shown: 65532 closed ports
PORT STATE SERVICE VERSION
80/tcp open http?
554/tcp open rtsp?
|_rtsp-methods: ERROR: Script execution failed (use -d to debug)
9530/tcp open unknown
MAC Address: 00:12:31:3F
D:94 (Motion Control Systems)
No exact OS matches for host (If you know what OS is running on it, see Nmap OS/Service Fingerprint and Correction Submission Page ).
TCP/IP fingerprint:
OS:SCAN(V=7.80%E=4%D=9/19%OT=80%CT=1%CU=30930%PV=Y%DS=1%DC=D%G=Y%M=001231%T
OS:M=5D834589%P=i686-pc-windows-windows)SEQ(SP=FD%GCD=1%ISR=101%TI=I%CI=I%I
OS:I=I%TS=U)SEQ(CI=I%II=RI)SEQ(SP=FE%GCD=1%ISR=101%TI=RD%TS=U)OPS(O1=M5A8SN
OS:N%O2=M5A8SNN%O3=M5A8%O4=M5A8SNN%O5=M5A8SNN%O6=M5A8SNN)WIN(W1=FFFF%W2=FFF
OS:F%W3=FFFF%W4=FFFF%W5=FFFF%W6=FFFF)ECN(R=Y%DF=N%T=FF%W=FFFF%O=M5A8SNN%CC=
OS:N%Q=)ECN(R=N)T1(R=Y%DF=N%T=FF%S=O%A=S+%F=AS%RD=0%Q=)T1(R=N)T2(R=N)T3(R=Y
OS:%DF=N%T=FF%W=FFFF%S=O%A=S+%F=AS%O=M5A8SNN%RD=0%Q=)T3(R=N)T4(R=Y%DF=N%T=F
OS:F%W=FFFF%S=A%A=S%F=AR%O=%RD=0%Q=)T4(R=N)T5(R=Y%DF=N%T=FF%W=FFFF%S=A%A=S+
OS:%F=AR%O=%RD=0%Q=)T5(R=N)T6(R=Y%DF=N%T=FF%W=FFFF%S=A%A=S%F=AR%O=%RD=0%Q=)
OS:T6(R=N)T7(R=Y%DF=N%T=FF%W=FFFF%S=A%A=S+%F=AR%O=%RD=0%Q=)T7(R=N)U1(R=Y%DF
S:=N%T=FF%IPL=38%UN=0%RIPL=G%RID=G%RIPCK=G%RUCK=G%RUD=G)U1(R=N)IE(R=Y%DFI=
OS:S%T=FF%CD=S)IE(R=N)
Network Distance: 1 hop
TRACEROUTE
HOP RTT ADDRESS
1 19.80 ms 192.168.2.15
Nmap done: 1 IP address (1 host up) scanned in 149.73 seconds
Raw packets sent: 66795 (2.947MB) | Rcvd: 66119 (2.646MB)
Any help - how to reset to factory settings? There's no pin onboard - I've checked it.
80/tcp open http?
554/tcp open rtsp?
TCP/IP fingerprint:
TRACEROUTE
HOP RTT ADDRESS
