Hello,
I have a system I put together that’s been running Blue Iris 24/7. Combination of 2 ACTi and a Dahua Mini PTZ.
Been trying to add a Hikvision DS-2CD2532F-IWS using PoE over CAT6 cable with a 40’ run. Connection is fine and setup is straightforward with SADP except for when I try to assign a different port from 8000. If for example I change it to 8094, I cannot connect. I can’t even login via WebGui. But if I leave it at 8000 and assign any Static IP, everything is good! What I don’t understand is why there is a Port assigned for iPV6 whose default I leave at 80. I tried changing this and same thing; cannot connect.
HELP please!
HELP please!
