Got a couple of Hikvision cube cams inside the house for when we are away at work and stuff.
Problem is, they feel very intrusive when we are there. Not to mention crazy russian hackers (no nothings default on ours, but that doesn't mean someone won't get lucky).
Looking for ideas on quick and easy disabling/renabling...
Pulling the power is impractical - I have these on PoE and don't want people fiddling with the RJ45.
One option *might* be to disable PoE on that port on the switch if I can figure out a simple way to do it (for other people to do it).
The most obvious way would be to throw a little hood over the camera - but I am concerned about overheating - they do run warm.
Best idea I have so far is to glue a couple of washers on and make a little (2x2") mask from card with a dome for the lens and a couple of small magnets so it can be quickly clipped over the front.
Perhaps you guys have tackled the problem in other ways?
