- Feb 22, 2018
- 21
- 5
Hi, I could use some help here. I have several of the IPC-T54IR-ZE-S3 around the building for security and getting animal triggers nightly that I can't seem to stop. I believe I have the right settings. Can use some ideas form fellow cam talkers.
Note: Motion Detection, Video Tampering, and Scene Changing = Disabled
Smart Motion Detection, Audio Detection = Disabled
Settings:
AI Type: IVS Intrusion: Enabled
1. Effective Target: Human & Motor Vehicle checked only
2. Actions: Appear and Cross with Directions: Both
3. Sensitivity: 4
Global Config:
1. Global Sensitivity: 5
2. Long Distance Mose: Disabled
3. Self Learning: Disabled
2. Linked Experience database: Animal Training (Used previous videos to discover and add animals)
Device ModelIPC-T54IR-ZE-S3
SN9F0EA64PAGC981E
Audio Input1
ONVIF Version23.12(V3.1.0.1734191)
System VersionV3.142.15OG001.0.R, Build Date: 2024-09-06
Web VersionV5.01.0.2036777
Algorithm VersionV4.5.9.0
Security Baseline VersionV2.4
H5Player VersionV3.01.1
Thanks
Guy
Settings:
3. Sensitivity: 4
Global Config:
SN9F0EA64PAGC981E
Audio Input1
Thanks
Guy
