I HAVE THE SOLUTION!!!! I HAVE FOUND THE SETTING!!!
For anyone using BLUE IRIS with the AXIS M3007-P Camera
It is possible to choose your custom stream.
- Add Camera
- enter IP address
- enter the admin username and password
- choose AXIS from the MAKE drop down
- Choose your model (I was using M/P/Q Series H264
- Click the FIND/INSPECT button
- Below the PATH and PARAMS boxes (leave them alone) is a CAMERA selection box. Choose a different camera option to change the stream.
- Click OK
Now, the CAMERA selection box does not allow you to label the stream, so it make take a few tries to find the digital preset you like. Additionally, changing the stream and clicking OK, Blue Iris will take a few seconds to acquire the new stream, so wait just a few sec.
Not sure if anyone on planet earth will find this useful, but it sure helped solve a huge issue for me.
I have the M3007 as well and am still struggling with this particular camera and the different "views" the camera offers. I've set up my view areas on the camera's webpage. And the streams do not work except stream "1". If I change the BI camera value to anything other than 1, it says "No Signal". And FluffyPony is right - clicking on inspect just resets it to a generic camera that doesn't work either.
I tried renaming the "View Areas" to be a single number like 2, 3, 4, 5 - but that had no effect either. I cannot get the panoramic view either - just the big fisheye view.
EDIT: I guess cam "2" is the panoramic and that appears to be working now. However, any other views/camera values give me an error RTSP: 400 Bad Request.
