Just remembered another one that I can't find the answer to. I am looking peeps honest. I have found most my questions answered.
As you may have gathered from the title it is about presets and zones.
I thought that you could set up each preset with its very own zones. But when I set up zones for preset one and saved, then opened up to do zones for preset 2 it looks like the zones from 1 has carried to 2. And also 3, 4, and 5. All of the presets have the green zones in the exact same place in your view if you understand what I mean. Scenes change, but the green zones are the exact same places, sizes, and shapes.
I did not try to give the other presets their own zones as I thought that would mess up preset 1 which I have how I like.
Thank You.
Thank You.
