I'm on firmware 5.3.8
Did anyone of you has 'preset freezing' function working when patrolling between presets?
I set patrolling function between some presets and I'm using 'Preset freezing' option.
Actually the patrolling function is not applying 'preset freezing' moving from one preset to the other.
This is quite an issue to me as without it, with slow connections, I'm loosing frames in zooming actions.
Anybody of you is aware of this issue and maybe has a solution?
Maybe it works but is not compatible with some complementary setting I used hence if anybody of you has success with it please share.
Did any of you has 'preset freezing' working with other Hikvision's PTZ?
Furthermore I'd like to use 'motion detection' for recording just the relevant 'motion episodes' of the single preset with the PTZ still 'patrolling' between presets.
Is there a way to obtain this or the continuously changing view prevents it?
Thanks in advance for any contribution!
