I am using the handy little feature of Pre-Trigger Video Buffer that allows me to capture video XX seconds before the event occurs. This feature works really well, however, it only works the first time after a camera reset/configure is saved. Entering and then saving Camera Properties... appears to reset the camera system, and when you initiate the first Trigger (either locally, or remotely via the Web API), the first XX second pre-roll works great. Every event after this, you no longer get a pre-roll of XX seconds. I will attempt to attach a picture below. If the system is set to stop recording 10 seconds after the event, then the first Clip will be 15 seconds, every Clip here after is only 10 (with the Clip starting point equal to the event trigger time)
I have tried 2 different POE cameras (Lorex/Vivotek), both work the same. The config of the cameras is pretty minimal, and also hopefully attached to this thread (myCam.txt is actually myCam.reg)
