When I click on an alert on the right side of BI, the object, a bicycle in this case, is already halfway through the screen. How do I get the alert to point to a time earlier, either frames or seconds?
I am using direct to disk recording on 10Hikvision and 1 Huisun (specs below)
I can move the pre-trigger frames all around with no change, 50, 25, 100, etc... but I expect this since I am recording continuously
i-frames match the frame rate
I am recording continuously, so really all I want is when I click on the alert, for it to start displaying earlier... someone on a bike is already halfway through the screen... sure, I can manually scroll backwards, but that is a pain...
I did lower the 'MAKE TIME" (motion sensor min. duration) to 0.4sec and it helped some, but if I go too low, I pick up too many false alerts...
hikvision(DS-2CD2132F-IS, DS-2CD2632F-IS, etc)
cam01 1280x720 max 30.0fps (333334) currently 25fps-480kB/s
cam02 1280x720 max 20.0fps (500000) currently 15fps-50.5kB/s
cam03 1280x720 max 17.5fps (571429) currently 15fps-52.5kB/s
cam04 1280x720 max 20.0fps (400000) currently 9.9fps-484kB/s
cam05 1280x720 max 17.5fps (571429) currently 15fps-485kB/s
cam06 1280x720 max 17.5fps (571429) currently 15fps-485kB/s
cam07 1280x720 max 17.5fps (571429) currently 15fps-30kB/s
cam08 1280x720 max 25.0fps (400000) currently 15fps-40kB/s
cam09 1280x720 max 15.0fps (666667) currently 15fps-30kB/s
cam10 1280x720 max 30.0fps (333334) currently 15fps-480kB/s
Huisun Gen2 10x PTZ camera
cam11 1920x1080 max 30.0fps (333334) currently 25fps-400kB/s
BI 4.3.9.7 x64
I am at 15% CPU on a i7 and using 1.15G Ram, recording to a single dedicate WD Purple 4TB drive, so performance is not an issue
-Mike in CLW
BI 4.3.9.7 x64
-Mike in CLW
