Been watching the thread for a while as a guest, first time poster.
I'm considering getting the Hikvision DS-KB8112-IM, still deciding on which indoor screen though.
My NVR is the HikvisionDS-7616NI-K2-16P.
What I was wondering is:
- Will I be able to power the DS-KB8112-IM directly from my NVR, since they are both POE? I'm a bit uncertain of different POE types, voltages and classifications
- Will I be able to add the DS-KB8112-IM to my NVR as if it was a normal IP camera in order to continuously record?
- This would be used by my front driveway gate, my assumption is that it shouldn't be too complicated to have this setup to open/close my gate?
- Is there any way I could have a reed switch attached to this unit as well to indicate whether my gate is open or close?
